Proper fix for rain squeal
arrrxivvv
Year and Model: 2004 XC70
Has thanked: 16 times
Been thanked: 10 times
Post by arrrxivvv »
Last Saturday in heavy rain I believe I've encountered the rain squeal on my 2004 XC70,
will examine for scoring mark on the propshaft when I have time, but pretty confident that it is, since it doesn't change with speed, only ever happened in heavy rain, and no pulling/vibration etc came with it.
The internet presents two fixes:
1. The JRL mod deleting the resonator
2. The updated bracket from Volvo
Some say that only deleting the resonator works.
So my question is does the Volvo updated bracket work for any of you? I'd prefer to go that route if it does, since it seems possible to diy.
04 XC70 206k
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Bracket solves it 100%
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
So something hot (and maybe out of position) is getting splashed and moving into the driveshaft?
Blacklab467
Year and Model: 2007 xc 70
Been thanked: 263 times
Post by Blacklab467 »
Never heard of this before, could someone please elaborate what the problem is and what it sounds like? Are you suspicious that driving in rain makes the prop shaft squeal, and what bracket is the solution?
2003 XC 70 (sold)
vtl
Post by vtl »
Blacklab467 wrote: 02 Apr 2024, 10:57 Never heard of this before, could someone please elaborate what the problem is and what it sounds like? Are you suspicious that driving in rain makes the prop shaft squeal, and what bracket is the solution?
Driving over puddle gets water on the bottom of exhaust, it flexes up and touches propeller shaft with the resonator.
Need to replace this with this:
https://www.fcpeuro.com/products/volvo- ... 0-30647428
https://www.fcpeuro.com/products/volvo- ... t-30793794
I actually cut the repair bracket in halves, so it does not dig into the dirt when I'm off the pavement.
arrrxivvv
Post by arrrxivvv »
Yes it's what vtl outlines below:
vtl wrote: 02 Apr 2024, 11:28
Thanks for confirming that the bracket works. and for the advice on modifying the bracket to improve ground clearance.
04 XC70 206k
arrrxivvv
Post by arrrxivvv »
BlackBart wrote: 02 Apr 2024, 09:44 So something hot (and maybe out of position) is getting splashed and moving into the driveshaft?
Most likely as vtl explains in another comment.
04 XC70 206k
Blacklab467
Did they actually update that bracket? It looks like the same one that’s on my car.
2003 XC 70 (sold)
vtl
Post by vtl »
Blacklab467 wrote: 02 Apr 2024, 16:50 Did they actually update that bracket? It looks like the same one that’s on my car.
Make a shot of yours?
Has thanked: 293 times
Been thanked: 765 times
That first link from vtl is a typo, it links to the original style bracket (Volvo). The updated bracket is these two links, Volvo or URO:
https://www.fcpeuro.com/products/volvo- ... t-30742265
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
