What would cause an alternator to fail? - Updated
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Re: What would cause an alternator to fail? - Updated
Post by BEJinFbk »
scot850 wrote: 11 Apr 2024, 08:44 Well if looks like I opened a can of worms for myself. Found a thread on Swedespeed which is full of some typical no knowledge speculation, but there is some curious stuff like Volvo changing the alternator supplier from Denso to Bosch and requiring a wiring change kit which I can not find anything about. The parts website talks about a 3 pole and 2 pole connector, but the car in question only uses one of the 3 wires in the connector and it is the middle one called A:1??
https://www.swedespeed.com/threads/s40- ... tby=oldest
You may be overcomplicating this 2/3 wire mention in relation to P80’s.
I’m not sure that a SS 2005-2012 S40/V50 section post is a fair comparison.
Volvo was a very different company at that point and with that car.
And I can’t remember ever seeing a P80 charging system with
anything more than a Big post B+ connection and the small lead
that operates the alternator light in the dash.
AFAIK, P80’s only shipped with Bosch self regulated “1 wire” alternators.
Has thanked: 1853 times
Been thanked: 1714 times
The issue is with an 06 V50 T5 AWD manual, and not a P80. The original question was on this forum as there is more traction on this than the P1 and I was looking for general ideas. This morphed to more targeting the issue on the P1.
No issue with P80's or their alternators or charging systems. Fairly simple even for me!!
Thanks though!
Has thanked: 1506 times
Been thanked: 3822 times
The fan vanes blow quite a bit of air through it and its heat load isn’t that high. I’m guessing alternators are 90% efficient, so a 100 amp alternator only has a heat load of 120 watts , one bright old light bulb
That’s only 84 watts , Canadian , too.
