97 960 - Would this cause P0410 SAS Fault?
brandoman
Year and Model: 1997 960
Post by brandoman »
Pulled off the air pump - noticed this:
The rubber mounts holding the air pump bracket are all worn off, and the air pump was "resting" on something causing this to wear through. Would that cause the error since it would effect vacuum. The air pump was blowing air, but not very much.
Could I epoxy that up?
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
If other vac lines in/around SAS are good, I'm sure that's your code source. Epoxy or a silicone sealant would patch it decently. If I were you, I'd get your multimeter out and check its impedance before reinstalling.
It doesn't blow much when it functions properly on cold starts. A very expensive little part to make cold starts easy.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
