As the later (94?-) control arms have no replaceable ball joints, and that is what mostly fails, you have little option other than buying OE. Lemforder used to make a decent unit, but I think TRW bought them over. Do you do the work yourself or pay someone to do it for you?
50kkm does seem low for control arms but that is what is the curse of the modern aftermarket part quality. I had the same issue with the Febi control arm I used on an 850 when it didn't even last that long.
Your options are slim:
1) Pay up for Volvo items in the hope they have not lowered their quality only upped the prices!
2) See if you can find a set of early aluminum control arms from a 92-4 850 which have a replaceable ball joint, but check the ball joint can still be found.
If you do the work yourself, it is a pain, but you do a higher than average mileage. Swapping out a control is not that hard and is fairly quick with practice!
Parts brands - OE Volvo, trusted aftermarket, and bad
- Has thanked: 2199 times
Ocelot , are the bushings bolt being tightened correctly with the control arms in the driving position? If they are tightened on the lift they will fail early. 150,000 KM should be lifetimeOcelot wrote: 22 Apr 2024, 09:11 So, today I received some disappointing news: the ball joints on my eleven month old wish bones have a lot of play. I've driven them for 35000 kilometers and they're from the Febi Bilstein brand. Had somewhat of the same issue with the TRW brand, but the TRW's lasted longer, somewhat of 50.000 kilometers and almost 2 years. Mind you, the Dutch highways are silky smooth. I'm a bit at my wits end... Replaycing the wish bones/ control arms every year isnt a solid strategy. Replaycing the control arms with brushings of PU rubber isnt something I like to do because usually that makes the riding experience very stif.
Whats your advice?![]()
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
Eh, when I think back... the first time I replaced them myself and the bolts were tightened on the lift. The second time was done by a local garage. You make me very curious... why do the control arms need to be tightened with the car on the ground?abscate wrote: 23 Apr 2024, 07:01Ocelot , are the bushings bolt being tightened correctly with the control arms in the driving position? If they are tightened on the lift they will fail early. 150,000 KM should be lifetimeOcelot wrote: 22 Apr 2024, 09:11 So, today I received some disappointing news: the ball joints on my eleven month old wish bones have a lot of play. I've driven them for 35000 kilometers and they're from the Febi Bilstein brand. Had somewhat of the same issue with the TRW brand, but the TRW's lasted longer, somewhat of 50.000 kilometers and almost 2 years. Mind you, the Dutch highways are silky smooth. I'm a bit at my wits end... Replaycing the wish bones/ control arms every year isnt a solid strategy. Replaycing the control arms with brushings of PU rubber isnt something I like to do because usually that makes the riding experience very stif.
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Because if you tighten the bolts with the wheels drooping, then set it down, the arms rotate, twisting the rubber bushings. So the rubber is already in tension and under load when sitting level, and they will wear out faster.
- Ocelot
Okay! Didn't knew that! I'm willing to ask a dumb question...
How is one to tighten the bolts with the vehicle on the ground? What's your approach to this?
Recent car
Recent car
You go on a crash diet of water for 6 months, lose 30 kg and slide under …..
Or
You carefully jack the wheel up the driving position on jackstands.
Or
tryingbe
- Year and Model: None
- Been thanked: 26 times
I use RhinoRamps at home when I have to tighten an suspension bolt, but I'd imagine solid wood pieces will be fine, if you have the parking brakes on.Ocelot wrote: 23 Apr 2024, 23:58 Okay! Didn't knew that! I'm willing to ask a dumb question...
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 71 times
Out with the...new, in with the....old?
Poor showing from a rein engine mount. I noticed it was bad on the second day after install.
Completely broken through. Surprisingly, not as bad as you'd think, but definitely noticable when accelerating, and some extra dull clunking.
Part number CRP-AVE0621. Id avoid like the plague.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.jsrnsis wrote: 20 May 2024, 19:31 Out with the...new, in with the....old?
In the early 2000 I installed a Rein mount just like that in a 98 S70 T5. Lasted about a year so don't buy it or it'll Rein on your parade.
That’s well struck there, BKM
10,000 points given
10,000 points given
