Is this rim repairable, and then safe to drive?
2020 V60CC - 36K Tune up
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Re: 2020 V60CC - 36K Tune up
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
This
Makes
Me
Crazy
I guess you teach yourself to live with it. To me it’s not visual and intuitive and direct.
A very unmechanical friend blew up his BMW 3-series because he didn’t understand the oil level system and blindly charged on.
- BlackBart
Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
Is this aluminum? There are wheel shops that can restore alum wheels to new. No idea the cost compared to finding a good used one.
xHeart
Found a replacement over Ebay; but then got the crack welded. The weld specialist says, aluminum wheel repairs and lasts forever. It won't crack at the same spot again.BlackBart wrote: ↑22 Apr 2024, 22:01 Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
.xHeart wrote: ↑15 May 2024, 08:48Found a replacement over Ebay; but then got the crack welded. The weld specialist says, aluminum wheel repairs and lasts forever. It won't crack at the same spot again.BlackBart wrote: ↑22 Apr 2024, 22:01 Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
Did you go to a wheel specialist or welder?
xHeart
Chicago Wheel Service in Elk Grove https://www.chicagowheelandtire.comMoVolvos wrote: ↑15 May 2024, 09:07.xHeart wrote: ↑15 May 2024, 08:48Found a replacement over Ebay; but then got the crack welded. The weld specialist says, aluminum wheel repairs and lasts forever. It won't crack at the same spot again.BlackBart wrote: ↑22 Apr 2024, 22:01 Something bad has happened to that wheel. The bead will hold air for now, but note the crack is traveling down from the lip into the bead.
- MoVolvos
.xHeart wrote: ↑15 May 2024, 09:32Chicago Wheel Service in Elk Grove https://www.chicagowheelandtire.com
Did you require some straightening or just welding? If you don't mind sharing the cost so we all can get an idea in case we need to find a local shop. Thanks.
xHeart
The quote was $140, it included removing wheel from the car (this-that-this-that) and then putting it back on after the repair. I walked in with just the rim and got it back the next day for less.MoVolvos wrote: ↑15 May 2024, 09:41.xHeart wrote: ↑15 May 2024, 09:32Chicago Wheel Service in Elk Grove https://www.chicagowheelandtire.com
- xiaofei204716
- Year and Model: XC90
- Been thanked: 2 times
Volvo, Lynk & Co, Polestar
VIDA is not required, if you want to direct or CEM PIN, you can contact me.
[email protected]
Five minutes to tell you the password, support VDASH/ORBIT/P3 TOOL/DSA
[email protected]
xHeart
One year since Matthew's ^ post. Our 2020 V60CC will be off the warranty soon.matthew1 wrote: ↑08 Oct 2023, 09:31 Here you go, this has fluids... but stubbornly doesn't address for instance auto transmission fluid replacement. It only, moronically, says "Automatic transmission fluid level, check/adjust". We all remember the P2 fiasco with "lifetime" fluid.
Maintenance_Volvo_Wty_Manual_2020.pdf
Now preparing for the 50K tune up - just oil and filters. The fluid refresh is coming in stages between 50 - 60K -- mileage when the spark plugs are due.
Fall weather is here.
