gas odor with full tank Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
For a while, I've had a fuel odor from the gas tank area with a full or half full tank. as soon as the level drips, the smell stops. I popped the fuel pump cover and nothing seems suspicious there. What's next? remove the right rear wheel liner/inner fender and look for a rotten hose?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Clemens wrote: 15 May 2024, 00:33 For a while, I've had a fuel odor from the gas tank area with a full or half full tank. as soon as the level drips, the smell stops. I popped the fuel pump cover and nothing seems suspicious there. What's next? remove the right rear wheel liner/inner fender and look for a rotten hose?
First thing to check is the rubber seal of the gas cap and the sealing surface where the cap meets the filler neck. If dirty stuff a rag in hole and use a 4 to 600 grit sand paper in circular motion to clean. Clean and vacuum before rag removal. Also, a very very thin film of silicone on the gas cap seal before checking for fumes on a full tank. You can also lightly film the gas filler neck area where the gas cap meets.
- Has thanked: 2200 times
What Mo Volvos suggests is great advice. Sometimes the simple stuff is all that is needed. Even swapping the fuel filler cap. I had to gently re-profile a filler neck on a friends car as they had somehow managed to dent the top edge.
Seeing a leak on top of the tank is also hard to see sometimes, including the seal on the fuel pump leaking.
I have a friends car to 'smoke' when they can make time to leave the car with me. It has a evap system leak which I am sure is above the tank where I can't currently access as there is a removable cover that can't be removes over the pipes. I may have to drop the tank eventually, no matter what.
I bought a cheap smoker off Amazon with additional plugs to allow it to build pressure by plugging pipes to atmosphere.
One quick question. Do you 'top off' the tank when you fill the car. So when the pump cuts off, do you try to add more fuel? Don't! In the newer P80's (not in fairness the older -98 cars with the carbon can at the front) it is possible to flood the carbon canister doing this which can lead to hard filling and fumes.
- Has thanked: 311 times
- Been thanked: 817 times
Get your head under the car and look around for stains on the side(s) of the fuel tank. That has shown me two different kinds of P80 leaks - when a hose on top of the tank was leaking and when the fuel pump seal was leaking. Especially take a look when the tank is full and it is smelly, may even see wet stains if you have that kind of issue.
- Clemens
Thank you, gentlemen!
I will follow your advice. I don't top off the tank. I will fill it up and look for wet stains on the side of the tank. And, since I have enough p80s, I might as well swap the fuel cap after cleaning the neck inlet.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- atucker1
- Year and Model: 1995 850 Turbo
- Has thanked: 11 times
- Been thanked: 15 times
You may have a very common problem with these 850s, which is a leaking vent hose on top of the gas tank. Unfortunately, the tank must be removed to replace the hose, which is a bit of a pain. As always, RobertDIY has a great video on how to do it. An easier solution that may work is to only fill the tank to a gallon or two below full, but might not work for you depending on the hose condition.
1995 850 Turbo, Sedan
1996 850 N/A, Sedan
1996 850 N/A, Sedan
- Clemens
cleaning the filler neck and switching fuel caps did the trick. Over 1000 miles and still no fuel odor.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1635 Views
- 38 Replies
- 9200 Views
Last post by jking4020
- 697 Views
Last post by jreed
- 1911 Views
Last post by fisker247
- 9 Replies
- 4850 Views
Last post by matt_linegar
