Post to this if you're having trouble. The server move thread.
- Has thanked: 2654 times
- Been thanked: 1248 times
I'm working now on bugs, but please post here if you see things that are not working correctly.
"Thanks for Posts" extension is bugged. Working on that.
Image Rotation has a bug saving the photo after rotation. Working on this.
(and when I say "working on it," I mean it's on my to do list...)
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
I'm not seeing some avatars for showing up. The site is leaving a blank for them. ZionXIX didn't show up, for instance.
Thanks for all of your work on this site!
FireFox31
Cookie settings are proving to be troublesome. This is the stuff that keeps you logged in. I'm experimenting with different combinations to make it work smoothly. Apologies if you're getting logged out!
You're welcome FF!
Thanks for reporting that avatars bug. That was an easy fix.
Image rotation test:
Ok, Image Rotation works. That photo above is [naturally] a completely normal, correctly oriented photo that I turned 180° with this new forum feature. You can go back to any photo you've ever posted to re-orient it, it's retroactive.
This is how you do it:
1. click the rotation icon next to the file name
2. then click on the image thumbnail to rotate it 90 degrees at a time
3. click SAVE IMAGE under the thumbnail
You do not need to Submit the post for this rotation change to take effect.
Notes for me down the line, please ignore: It works with php8.2 and 8.3.
- Has thanked: 927 times
- Been thanked: 1000 times
This change will be very cool! Thanks.matthew1 wrote: ↑20 May 2024, 09:18 Ok, Image Rotation works. That photo above is [naturally] a completely normal, correctly oriented photo that I turned 180° with this new forum feature. You can go back to any photo you've ever posted to re-orient it, it's retroactive.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
When I was logged off and clicking Page 335 of "What did you do to your P2 Volvo today?" from the Active Topic page
