850t driver axle replacement.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
It looks like I may simply be able to disconnect control arm at the ball joint attachment, remove axle nut and swivel hub outward so I can then access the axle as seen here: Maybe not remove inner bolt from the control arm at all. Last time I did this I was replacing the control arm and axle shaft but this looks like it might work with just a couple of steps. Am I missing something? Thanks.
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
I tried the same path last time when I replaced the passenger side wheel bearing. It turned out to be a bad idea because the steering knuckle "clamp" around the control arm ball joint broke due to its age. When I tried to "enlarge" the clamp with a chisel (or big flat head screw driver). New steering knuckle was hard to find. I ordered new one from dealer and it took about 1 month to get it.
So I would undo the control arm from the sub-frame side rather than from the ball joint side.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
You don't need to open that "clamp" you just have to remove the bolt completely to get it to drop off the spindle.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
lcc014
Post by lcc014 »
jmartin919 wrote: 28 May 2024, 08:42 You don't need to open that "clamp" you just have to remove the bolt completely to get it to drop off the spindle.
Unfortunately, mine did not drop down. I wished it did but not the case. My 1995 850 was about 29 years old and it was the original steering knuckle which needed to "open" the clamp in order the drop the ball joint down. The "new" steering knuckle that I ordered from dealer was a different design. The ball joint clamp area was very loose; ball joint would drop down once the bolt was removed.
jmartin919
OK, that's different. I have a 93 850 and it just drops down. Have to be very careful it's fully seated back up in there before reinstalling the bolt - ask me how I know.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
My '93 actually has the replaceable ball joint on the control arm.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
lcc014
Post by lcc014 »
Volvo changed the control arm design in 94/95, no more replaceable ball joint on the control arm. Mine is one piece control arm.
Has thanked: 1839 times
Been thanked: 1709 times
They are interchangeable. Some like the idea of the replaceable ball joint and the aluminum control arms. They will be hard to find these days. I used to have a spare set that someone decided they needed so I sold them.
