Help identify unknown drooping wire for 1996 850 Turbo Sedan Topic is solved
Birddd
Year and Model: 1996 850 Turbo
Post by Birddd »
Hi all, was hoping somebody could help identify the cable that is drooping and if I can just zip tie it since it appears to be held by only one clip on the right passenger side
Located at the bottom front of the car with pictures to help
It’s the black cable I have held with my finger in one of the photos
Has thanked: 1614 times
Been thanked: 4078 times
That looks like evap line running back to the fuel tank. It needs to be zip tied and chafe relieved so it doesn’t get a hole in it.
Birddd
Post by Birddd »
Thank you for the identification, Forgot to mention there seems to be a corroded part, thoughts on this?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I would take a short length of heater hose, split it and put it over that plastic hose before that one breaks.
I imagine that you could also cut that bad section out and replace with a piece of rubber hose, though it might need to be fuel rated.
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
That doesn't look corroded. It looks like it got over-sprayed with some undercoating, or the like, and has collected dirt on it over time. Kind of like half of the other stuff I see in the pics under the car.
Birddd
Post by Birddd »
That’s what I concluded as well thank you for the input
Sveedy
Post by Sveedy »
Good catch there Chuck ! :)
1999 V70 GLT
Has thanked: 2215 times
Been thanked: 1853 times
Soak a small patch of rag with WD-40 and rub the pipe with it and see if the undercoat comes off. If it does you know not to worry about it!
Birddd
Post by Birddd »
Oh awesome thanks for the tip Neil
