2006 xc70 170K. CEL went on. My scanner says: 614B Camshaft Control, Exhaust, Faulty. I cleared the code, drove 170 miles, CEL went on with same code. I did some 'googling' to find these possibilities:
Low oil pressure
Poor oil quality
Damaged reset valve
Mechanical fault in the variable valve timing (VVT) unit.
The oil is spot on, recent change about 1K ago. Mobil 1 as usual. How would I check the other factors? I am a DIY-er....I can fix most anything IF I KNOW WHAT IS WRONG! Any input?
The fun never ends: CODE 614B...what do I do?
- Has thanked: 2215 times
- Been thanked: 1853 times
What oil viscosity are you using?
Neil
Neil
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Exhaust side camshaft solenoid may be gummed up. You can take it apart and attempt cleaning it, most just replace it.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 15 Replies
- 2643 Views
Last post by j-dawg
- 571 Views
Last post by dairyqueen814
- 1110 Views
Last post by matt_linegar
- 1402 Views
Last post by E Showell
- 739 Views
Last post by vtl
