Electrical issue...need help
2006 xc70. I put new LED bulbs in last year- everything was great till last nite. Driving home, I noticed the lights were dim...upon arriving home, the lights were no brighter than an old flashlight... Revving the car does not increase the brightness. What should I explore? What is the voltage that I should expect from the battery at its terminals? What is the voltage I should expect at the headlight sockets? I will try to look around for any 'loose' connections...Don't know what else to do? My local mechanic is off for 2 weeks, I'm afraid to drive too far from home. Alternator?
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
Electrical system should be at 13.5V when running. If 12V or lower likely the alternator. A cheap voltmeter or Amazon USB socket with voltage readout in the cigarette lighter will do the trick.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
I’d just change the bulbs with a halogen to isolate the headlight circuit.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
