Hello,
I have a 2005 Xc90 2.5t AWD. I am receiving the Power system urgent message. New Alternator installed before I purchased it, less then 200 miles ago. New Battery. I have a copy of VIDA/DiCE. which is showing me a CEM-30 fault. no signal from ACM. Thought the voltage regulator might be the wrong one. (computer excited is correct for my car). Installed a new one from IPD and double checked Bosch number with volvo to my VIN. I have checked to be sure no short to ground from green/white wire on alternator to pin #16 on on ECM.
I get 13.56 VDC when running and voltage stays steady when lights, radio, AC on.
Total loss on what to do next.
Thanks in advance for any thoughts!
Need Help from the Electrical guru's! - Power System Urgent message
adrian22
- Year and Model: s60 2006
have you fixed your alternator problem? I have exact same issue-alternator output low to 13.5 under load and power system message on I am courious if you replaced the alternator or just voltage regulator
adrian22
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
13.5v I believe is the default when the alternator and CEM aren't seeing each other over the LIN data connection. Normally when running it should be between ~14 - 14.7v depending on the charge state of the battery and vehicle electrical loading. The CEM determines what it 'wants' and tells the alternator what voltage to run at. Why they aren't communicating could be anything from terminal corrosion/break in continuity of the wire, to a problem with the voltage regulator and lastly (but possible) an internal failure with the CEM.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
13.5V is a tricky charge. After 2005 Volvo (among other cars) started using what's called 'smart' regulators. These lower the output (even as low as 13.5V) when the battery is fully charged. On cars prior to 2004 a 13.5V charging would meant a worn battery or a faulty alternator (or cables).
How is the battery voltage 30 min after shutting off the engine? Measure with only the trunk open and all lights (including trunk lights) off - pull a fuse to turn trunk lights off faster.
Another way to check a smart regulator is to have the engine warmed up then shut it off and let the battery drain for 5 min. with the headlights on and key in POS II (engine off). Then start the engine and measure the voltage: the smart alternator should be in battery charging mode somewhere near 14.5V.
adrian22
thanks for suggestions
my car is a 2005 xc70- 120k and I am not sure if it has a smart regulator or not-I assume it does since the default 13.5v charge.
My alternator has an exterior plastic box attached to alternator and if I search for Voltage regulator part it shows me that part as a separate part for under $50
Maybe i can just replace that instead the alternator that looks ok
Battery is new and shows 12.6 with engine off in the morning overnight rest
I get 13.5 V when running w/no load voltage stays steady but under load(ac/fog lights/heater/lights) drops to 12.8.
If I let the car run 15 min after the engine is off the battery reads 12.8, meaning the alternator is charging and is working.
I assume since the battery and alternator is ok the only part left is the voltage regulator defective
I am right-please correct me if wrong?
adrian22
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Lot of information, may or may not be of help-
Design
Generator (GEN) design, not B8444S
The main components of the generator (GEN) consist of:
Stator, Rotor with slip rings, Integrated cooling fans, DC bridge, Charge regulator, Pulley
Generator terminals- non B8444S
Generator (GEN) terminals:
#A:1. B+
#B:1. To central electronic module (CEM) or engine control module (ECM).
Alternator structure, engine B8444S
Alternator connections, engine B8444S
#A:1. B+
#B:1. To engine control module (ECM)
#B:2. Not used
Stator
The stator is fixed and consists of grooved plates which are insulated internally and pressed together onto a fixed plate unit. The stator winding coils are positioned in the grooves. They are delta connected at 120° and provide a three phase alternating current to the rectifier bridge.
The rotor consists of two halves (claw-poles) which interlock. The halves are pressed onto the rotor shaft. There are twelve claws on the rotor, i.e. twelve poles. One half consists of six north poles and the other half six south poles. The excitation winding is secured on the rotor shaft between the claw-pole halves. The excitation winding (also known as rotor winding) consists of a circular coil surrounded by the claw-poles and connected to the slip rings. The charge regulator supplies a magnetic current through carbon brushes positioned against the slip rings. The higher the current in the rotor the stronger the magnet field of the rotor, and therefore the higher the current generated in the windings of the stator.
Cooling fans
The heat generated in the generator is, in principle, proportional to the current generated and must be directed away to prevent damage to the insulation and diodes. The generator (GEN) is therefore air cooled and equipped with two integrated cooling fans on the rotor shaft.
Rectifier
Alternating current (AC) is created in the generator stator windings. This must be converted to direct current (DC) before it can be used in the electrical system of the car. This conversion is made using a rectifier bridge which consists of six diodes, two diodes per phase winding.
The stator windings generate three phases and are delta connected An exciter diode is connected to each of the three stator windings. The six rectifier diodes are bridge connected. The diodes are pressed into a diode holder.
The generator (GEN) has an inbuilt charge regulator at the rear (also known as the alternator control module (ACM)). The regulator can be replaced. The carbon brushes are integrated on the slip rings on the rotor on the regulator.
Charge voltage
At room temperature a fully charged battery cell produces 2.12 V. A 12 V battery has 6 cells and therefore produces 12.72 V when the battery is fully charged. The battery has an internal resistance which must be exceeded before charging can take place. At room temperature 0.2 V is required per cell, or 1.2 V for the entire battery. Therefore to charge a battery at room temperature, 13.92 V (12.72 V+1.2 V) is required. In cold conditions, the chemical reactions take place at a slower rate and the internal resistance increases. This requires a higher voltage during charging to exceed the internal resistance. The charge regulator, depending on how it is controlled by the central electronic module (CEM), regulates the output voltage so that the battery receives optimal charge.
If the charge regulator is connected to the engine control module (ECM), it will use the commands from the engine control module (ECM) and central electronic module (CEM) to regulate output voltage so that the battery is charged optimally.
Depending on the model year and type of engine management system, the charge regulator (also known as the alternator control module (ACM)) is connected to either the central electronic module (CEM) or the engine control module (ECM). It communicates via LIN communication. For information on connection, see the illustration above and the wiring diagram.
If the charge regulator is connected to the engine control module (ECM), the engine control module (ECM) then communicates with the central electronic module (CEM) regarding alternator control via the controller area network (CAN).
The central electronic module (CEM) has built-in functions for regulating voltage level and current consumption in the vehicle. The central electronic module (CEM) controls the charge regulator either directly or via the engine control module (ECM). In this manner, it also controls the current/voltage produced by the alternator.
The generator does not initially charge when the engine is started. The charge increases successively when the engine has been started. When there is an increase in load at the generator, the increase from 0 – 100% takes place over the course of a few seconds (this time varies slightly depending on the operating mode the engine management system is in). This is to gradually increase the load on the engine during the start-up phase and to ensure the engine starts.
If the engine speed (RPM) exceeds idle speed (the exact engine speed varies slightly depending on the mode the engine management system is in) during this delay, or if the progressive increase is interrupted, full charge is obtained immediately.
If there is no communication with the charge regulator, the charge regulator will not start charging on start-up. The charge regulator can however self magnetize the rotor and start charging. This occurs at engine speeds greater than approximately 2100 rpm. There is no charge engagement by stages with self magnetization, the generator operates at full charge immediately.
When self magnetizing has begun, the generator (GEN) also charges at engine speeds below 2100 rpm.
Can see- http://www.volvowiringdiagrams.com/volv ... agrams.pdf, pg 61 for the electrical path.
Were I to hazard a guess, I would agree with mrbrian on there being an issue with communication between the ACM and the CEM.
edit- add last comment
Design
#A:1. B+
#A:1. B+
#B:2. Not used
Stator
Cooling fans
Rectifier
Charge voltage
