What is this hose on the rack and pinion specifically?
AylmerQc
Year and Model: 2007 XC70
Has thanked: 60 times
Post by AylmerQc »
2007 XC70 Cross Country..
I was advised by a local garage that did an inspection on my car that this hose should be replaced.
It's situated at the front of the R&P.
Anyone with previous experience changing one of these?
What would be the part number or the name. Is it the high pressure hose or the low pressure one?
Been thanked: 471 times
Post by cn90 »
Just keep an eye on it for now.
viewtopic.php?t=63143
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
I would hose it down with Fluid Film or ACF-50 to prevent rust from going further.
08 C702.5T (sold)
The non-Swedes:
AylmerQc
Post by AylmerQc »
Thanks. I'll need to look those up. I'm not familiar with them. I thought maybe a WD-40 product or what I've seen locally (in Canada) a rust convertor fluid...but not those brands...if that's what they are...
Krons
Post by Krons »
AylmerQc wrote: 11 Jul 2024, 11:26 Thanks. I'll need to look those up. I'm not familiar with them. I thought maybe a WD-40 product or what I've seen locally (in Canada) a rust convertor fluid...but not those brands...if that's what they are...
Fluid Film or ACF-50 will take longer to wash off than WD-40. You could even take a brush and coat it with grease, need something heavy to stay on there a while.
08 C702.5T (sold)
The non-Swedes:
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
follow the hose by feel to identify which one it is, its days are limited.
deano1
Year and Model: 2001 s60 1999 awd
Has thanked: 13 times
Been thanked: 16 times
Post by deano1 »
Yeah, eventually those lines will fail and I'm not sure if Volvo still stocks them?
The good news is if the rack is in good shape otherwise you can fabricate your new lines using a bubble flaring tool and 1/4 or 6mm "cupronickel" tubing.
Not a bad job once the rack is out of the car. Would be a nightmare job otherwise.
v70waggin
Year and Model: 2005
Has thanked: 3 times
Post by v70waggin »
AylmerQc wrote: 10 Jul 2024, 17:12 2007 XC70 Cross Country..
The lines are available from the UK, would definitely have to drop the subframe
See viewtopic.php?p=649036#p64903
