2007 XC70 Cross Country..
I was advised by a local garage that did an inspection on my car that this hose should be replaced.
It's situated at the front of the R&P.
Anyone with previous experience changing one of these?
What would be the part number or the name. Is it the high pressure hose or the low pressure one?
What is this hose on the rack and pinion specifically?
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I would hose it down with Fluid Film or ACF-50 to prevent rust from going further.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
AylmerQc
- Year and Model: 2007 XC70
- Has thanked: 62 times
Thanks. I'll need to look those up. I'm not familiar with them. I thought maybe a WD-40 product or what I've seen locally (in Canada) a rust convertor fluid...but not those brands...if that's what they are...
- Krons
Fluid Film or ACF-50 will take longer to wash off than WD-40. You could even take a brush and coat it with grease, need something heavy to stay on there a while.AylmerQc wrote: 11 Jul 2024, 11:26 Thanks. I'll need to look those up. I'm not familiar with them. I thought maybe a WD-40 product or what I've seen locally (in Canada) a rust convertor fluid...but not those brands...if that's what they are...
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
deano1
- Year and Model: 2001 s60 1999 awd
- Has thanked: 13 times
- Been thanked: 17 times
Yeah, eventually those lines will fail and I'm not sure if Volvo still stocks them?
The good news is if the rack is in good shape otherwise you can fabricate your new lines using a bubble flaring tool and 1/4 or 6mm "cupronickel" tubing.
Not a bad job once the rack is out of the car. Would be a nightmare job otherwise.
v70waggin
- Year and Model: 2005
- Has thanked: 3 times
The lines are available from the UK, would definitely have to drop the subframeAylmerQc wrote: 10 Jul 2024, 17:12 2007 XC70 Cross Country..
See viewtopic.php?p=649036#p64903
- 1318 Views
- 1330 Views
Last post by oragex
- 480 Views
Last post by stevolvos60
- 546 Views
Last post by j-dawg
- 1526 Views
