I have a 2011 XC 70 that randomly goes dead overnight. I found it once with the flashers on, so I assumed it was a bad siren module. I pulled the module from the wheel well. It still randomly goes dead.
Strangely when I hooked it up to the charger, the horn started blowing, which I assume was caused by the door being opened to pop the hood. I assumed the alarm would be inop due to the missing siren.
I don't need an alarm.
Any ideas what the issue might be?
Thanks!
2011 XC70 Overnight dead battery with no Alarm Module
davewave365
- Year and Model: 2011 XC70
- Been thanked: 2 times
AVOIT17
- Year and Model: 2009 XC90 RD
- Has thanked: 6 times
- Been thanked: 16 times
This has happened to me as well 3 times with an 2009 XC90 and once with a 2011 XC70.
Since these events are unusual/intermittent they are very difficult to diagnose if not impossible.
If this happens regularly you may want to measure the 'parasitic draw' on your battery to see if it is beyond normal. If it is, then there is a method to determine the source of the unwanted drain.
Google on YouTube "Parasitic Draw"
davewave365
Found it. Sirrus XM stuck on update. Known issue, there is a TSB/lawsuit in the works. Pulled the power plug and installed shunt so the radio still works. Volvo part # 8688083.
- 1631 Views
Last post by jonesg
- 846 Views
Last post by difflock54
