Definitely the better option, too me.bmdubya1198 wrote: ↑24 Jul 2024, 20:31 The 850 OBD app is probably the best solution at this point, considering all of the additional functionality that's included with it.
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 130 times
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
didn't know that one yet. Thanks!bmdubya1198 wrote: ↑24 Jul 2024, 20:31 The 850 OBD app is probably the best solution at this point, considering all of the additional functionality that's included with it.
After updating the dash and rear speakers I did the doors today. Meh, I hate audio work, nothing fits, I had to resize the adapters etc. But I think it came out good. Not sure if it was worth the work (2 days for all 8 speakers), but it is done.
850 T5-R '95 auto
MotorTheresa
- Year and Model: V70 1998 B5252F/S MT
- Has thanked: 31 times
- Been thanked: 11 times
Today I have cleaned the engine bay.
Nothing fancy, no plastic shine just good ol' soapy water and brush. The passenger side water drain hose was clogged all the way, lol. Other than that I have soldered in spare Relais' into my troubled IMMO Module per xanthefin's suggestion.
Test run forthcoming. Have a nice evening
- Has thanked: 1505 times
- Been thanked: 3818 times
Flying back to my trusty 1999 waiting for me I. The lIRR parking lot.
LAX-EwR tonight
LAX-EwR tonight
hausmeister
I'm working on the sunroof this week. Not really comfortable with this job, but leaving it to rust also isn't an option at this point. Half the glass came off the severely rusted frame, the other half was hard to remove. Sadly I scratched the glass during removal, but I will live with that.
Still in progress. I fixed the frame to my ability (rust converter+sealer), cleaned everything and glued it together again today. Not sure I did it right, but I did the best I could.
I do have a new original gasket, bought it after I got the car but never started the job. That will be the next part, hope I get all this right enough.
850 T5-R '95 auto
- Has thanked: 1850 times
- Been thanked: 1710 times
Can you polish the scratch out with jewelers rouge?
abscate wrote: ↑30 Nov 2023, 19:37 Kat stranded me today. Slight surging as I pulled up the hill the one mile to the train station, then dropped to an idle amd stalled just as I pulled into 25A major route. Pushed to side.
Cranks m fires , rough idle , then stalls. Feels the poor fuel delivery problem. Hope the pump hasn’t come loose.
Got the solid tow bar out and recovered it home Have to travel out of town this weekend so no time to diagnose until next week
Flashers ran battery out in 15 minutes, 5 year old battery.
Not sure I followed up on this. I ran out of gas. Idiot!
If I can sneak my tools on Viking next week , I’ll stop by in Wien……hausmeister wrote: ↑30 Jul 2024, 09:28![]()
hausmeister
Sure, I installed it again today, so done with it for now. It is still binding a bit on the rear, but I could not adjust it any better. Hope that goes away with the gasket getting in form somehow.
850 T5-R '95 auto
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 41 times
- Been thanked: 28 times
I replaced all 4 wheel bearings as a precaution. On my 2002 S80 with approx 230K kms a wheel bearing had started to make noise and I figured on the one year older and 30K kms more experienced C70 its factory original bearings would not be far behind.
On the S80, 3 of the 4 bearings showed signs of getting close to worn out. In the C70, interestingly, all 4 bearings felt like new! It was a bear to get the front ones out. Heat, pounding and angle grinding involved. The rears were super easy with that one large nut holding them on.
Anyways, should be good for the next twenty years ...
