It is worth checking Abscates 2nd go at the pump. He found a great way to drop the rear end just enough to access the pump without removing it all. It saves a lot of time. He used some threaded rod to allow the rear to be dropped only so far.
98 V70R fuel pump!
- Has thanked: 1842 times
- Been thanked: 1710 times
Re: 98 V70R fuel pump!
tsinfinite
- Year and Model: 1998 V70R
- Has thanked: 11 times
That's fabulous, I will definitely check it out. I really am not fond of the hacking idea and extra especially if there's a much minimized time/effort process without that necessity
Corrosion of the mounting bolts on the rear subframe is the largest issue here. While in there check the subframe aluminum around the mounting bolts if/when you get them out and also mostly at the rear of the mounts at the fender rear. For some reason the RH side is typically the worst for some reason.
Good luck!
Good luck!
tsinfinite
Tending to agree
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
If it quits at an inopportune moment it could lead to a poor outcome. If there isn't a lot of rusty stuff on the rear awd bits - somewhat unlikely - letting the rear subframe down far enough to reach the pump might work. Cutting the access panel if done carefully is something that's done even in professional shops; GM sent a tech sheet to their dealerships about cutting inner fender skirts on V8 Monzas and Astres to get to the rear spark plugs. Ask how I know.tsinfinite wrote: ↑26 Jul 2024, 07:55Tending to agreehaven't yet looked at the (2nd) Abscates process, the issue hasn't arisen again (yet), car doesn't get driven a lot so can likely employ the "bang on that thang" process for a time yet if it does pop up, but I've gotten over the "don't hack up" ... a 26 y/o, not super rare, turbobrick shitbox
(affectionately stated that, of course)
More than one flat-rate mechanic cut a hole in the firewall of a Pinto to change the cam without pulling the head, but you had to be careful with the radio.
Sucks you couldn't run the use the radio while doing the cam swap!
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 89 times
My '98 was a New York car its whole life and I just hit the subframe bolts in back with PB Blaster a couple times a day for a week. All came out without issue. Might be worth trying to drop the subframe down a little to access ala Robert DIY - I hate the idea of hacking up the car to do the pump
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
- Has thanked: 1502 times
- Been thanked: 3817 times
I want to say just dropping the forward trailing arms, driveshaft, and VC gives you enough to then pry down the tank and get the pump out, blocking it with wood. An experienced Volvo tech told me that works.
My write up is here.
viewtopic.php?t=95586&hilit=Ekaterina&start=90
Other work on the car is cross referenced in the maintenance forum , linked below in my sig
This car is named “Ekaterina” or Kat for short
- 42 Replies
- 10150 Views
Last post by Maestrours
- 4375 Views
Last post by wizechatmgr
