(Solved) 98 V70 I Fenix - OBD ECM readout with LED not working Topic is solved
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 31 times
Been thanked: 11 times
Post by MotorTheresa »
Good evening,
Since blue V70 is on the road again I wanted to get a deeper look into the ECM and its DTCs. Getting a bad start occasionally which throws a DTC.
Used this LED rig described here http://volvo-turbo.de/obd-ii.html but LED stays dark. Always.
Am I doing something wrong?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Fuse ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MotorTheresa
misha wrote: 07 Aug 2024, 12:01Fuse ok?
checked all fuses. I say: yes
misha
Post by misha »
Possible reversed led polarity?
Did you tried it directly to a car battery?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
Never used that gadget... Are you sure it is wired correctly? - I can't tell from the picture.
You can start by checking if there is the correct voltage for the led present after the resistor and 12v before.. and go from there I think. Test the LED separately etc. probably needs 1-3v. But you probably already got it working I hope.
Also why are you using pin 3?
In any case good luck with the Fenix.
850 T5-R '95 auto Image
MotorTheresa
Apologies, I just saw your replies here. Will follow the suggestions and check, then come back. Topic still open. Since I get MLC on rough startups it would be just perfect to see what's behind that hardware wise :)
Will follow up here, sorry for the late response.
Has thanked: 1850 times
Been thanked: 1712 times
Have you got the ignition on to position II when testing?
MotorTheresa
Yes, Pos II
MotorTheresa
misha wrote: 17 Aug 2024, 13:20 Possible reversed led polarity?
Today I have turned to this task again and indeed found the LED polarity wrong ... So, good hint!
Resoldered and will test tomorrow.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
It is possible you will need to replace the LED with a new one as incorrect polarity can cause them to fail
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
