Turned the Drl’s off, it’s something I tried to ignore because I thought it would be a big endeavor. I found out about that little screw next to the light switch, so awesome of Volvo to do that.
Unfortunately, my screwdriver was a bit big and I didn’t walk the hundred feet to get a smaller one so I buggered the hole a bit. Oh well it blends in with all the other imperfections.
5underpressure
- Year and Model: 1998 v70
- Has thanked: 11 times
- Been thanked: 13 times
- Has thanked: 304 times
- Been thanked: 517 times
I do love that they did it that way. I don't like DRLs when they're nothing more than the regular low beams.5underpressure wrote: ↑08 Aug 2024, 15:18 Turned the Drl’s off, it’s something I tried to ignore because I thought it would be a big endeavor. I found out about that little screw next to the light switch, so awesome of Volvo to do that.
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
Hmm, this looks suspect. Brief research shows there isn't a gasket for P80s here but later cars do have a gasket. Has anyone adapted one before?
Last night I got the oil pan back into the car and bolts torqued. Very tricky to get the pan in without smudging the sealant, and I didn't like how far over I had to pull the power steering lines.
Also had a fight with the AWD engine mount.
Not sure this is going to be the issue. It was original to the car, but I read about adjusting the positioning of the bracket on the threaded rod changing vibration, and I remember when I put the top torque mount in, I had to jack the engine up on the transmission side to get the bolt in. But there was no way I could have adjusted it in the car with the amount of violence it took to get the retaining nut off the old mount.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- Has thanked: 1850 times
- Been thanked: 1712 times
Sorry, having difficulty orientating myself to the first picture. Is it the exhaust manifold?
jsrnsis
That is looking up at the back of the engine as if your head was on the passenger side and feet dangling out from under the drivers side. That's the flange from the turbo to the downpipe.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
There should be a gasket from what I can see on a parts drawing. However, it looks like it is NLA:
https://www.volvocarstorontoparts.ca/p/ ... 75549.html
This is the muffler parts drawing for a 98 turbo engine:
https://www.volvocarstorontoparts.ca/a/ ... 69044.html
You may have to try for aftermarket suppliers for down pipes to get a suitable gasket or a muffler shop possibly?
jsrnsis
Interesting, for the AWD it shows no gasket there. But it does show a gasket between the turbo and exhaust manifold, which I had the understanding did not have a gasket. Trying to look for leaks between turbo and downpipe or residue doesn't produce many results, but does show many results for leaks between the turbo and exhaust manifold.scot850 wrote: ↑09 Aug 2024, 17:08 There should be a gasket from what I can see on a parts drawing. However, it looks like it is NLA:
- exhaust1.PNG (164.24 KiB) Viewed 220 times
- turbo1.PNG (241.55 KiB) Viewed 220 times
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- Has thanked: 1506 times
- Been thanked: 3818 times
There is a thin metal gasket there. Probably aftermarket only. I will look in my stash at home in a few days.
Fact check ? Might be bad info above.
Unless it is a cup and ball design on the muffler there, it will need a gasket. As you may know, the joint behind the cat to the rear muffler pipe had that type of joint.
Sorry, did not pick up it was an AWD car, although you do mention it and it has an AWD trans mount! D'oh!
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
Meh I should also drop the pan... is it possible to sneak in new rod bearings at the same time? I have seen people on yt do this on other cars just with the pan removed.
Anything else that you should do at the same time? engine mounts maybe?
850 T5-R '95 auto
