Tail Light Replacement for 2015 S60
Argon522
Year and Model: 2015 S60
Post by Argon522 »
Hi all,
I recently had a self inflicted incident requiring replacement of the passenger rear tail light assembly.(I stumbled while carrying a jack and cracked the side of the lens). After searching around I found there is not a lot of info out there on how to do this, so I have documented the process to hopefully help others.
Notes:
This is a long process due to the number of parts you have to remove, but not hard and does not require lifting the car. It can be done solo, though an extra pair of hands can help when handling the rear bumper.
What you will need:
-T20 socket
-8mm socket
-Short socket extension(maybe 3 or 4 inches)
-Flat blade screwdriver
Step 1: Remove the rear bumper
I have seen some suggestions to only pull out half the bumper for the side you are replacing, but it will be much easier and less effort to just pull the whole bumper.
1A: Remove bumper fasteners.
There will be 5 T20 in each wheel well, 4 down the outside edge and 1 on the bottom, see the blue circles below. Remove from both sides of car. The were only about finger tight.
Wheel well bolts
Wheel well bolts
There are also 4 8mm bolts along the bottom approximately under the parking sensors if equipped.
Under bumper bolts locations
Under bumper bolts
Under bumper bolts
Step 1B: Pull bumper out of clips
Starting at the right side wheel well. Pull the bumper straight out from car until clips release. I suggest using the top of the lip on the wheel well as a grabbing point. This might take a good sharp tug. For the bumper clips always try to pull straight away from the car body to prevent damage. Work your way under the tail light pulling and releasing clips. You should not need to use any prying tools.
:!: There is an electrical connector for parking sensors(if equipped) in the bumper below the right taillight :!:
Once you have the right side of the bumper pulled out, remove the electrical connector for the parking sensors. Use the flat bladed screw driver to press in the release tab and wriggle the mating connector to release. The connector may be slid toward the wheel well to free it from its mount and give some more room to work.
Sensor connector
Sensor connector
Sensor connector 2
Sensor connector 2
Release the bumper on the left side same as on the right, working from wheel well towards the rear.
Once both sides are released the bumper should pull straight back and off. Set aside taking care not to scratch the paint or damage any sensors.
Step 2: Remove first body moulding
:!: The body moulding directly under the tail light contains the radar unit, be careful when handling :!:
Remove the 4 8mm bolts holding the moulding in place. The moulding should now be able to be moved out of the way. I just flipped it down and let it hang from the harness. Be careful to not hit the radar unit (large box in center of moulding) when removing bolts.
Radar mount bolts 1
Radar mount bolts 1
Radar mount bolts 2
Radar mount bolts 2
Step 3: Remove second moulding
This one is a bit trickier. Remove the 2 8mm bolts along the top edge. You will then need to pull straight down on the top edge to release the pins from the holes in the body, then while pins are out pull top edge toward you, away from the vehicle until clear of the body. This will take a bit of force to do. You can then lift straight up on the moulding to remove from the center retaining post.
Wheel well bolts
Wheel well bolts
Step 4: Get access to tail light inside trunk
Remove the panel used when changing bulbs. It should just pull out.
Light change panel
Light change panel
Reach around to back side of the plastic panel clip and squeeze in tabs to release.
Pin to remove
Pin to remove
Pin release tabs
Pin release tabs
Pull carpeting straight out. Mine was split around the back side of the trunk hinge so it could just be pulled out and around it. If yours isn't you may need to make a cut.
Carpet pulled back
Carpet pulled back
Pull carpeting back, you should have enough room to work without needing to remove it further.
Step 5: Remove tail light assembly.
Remove the electrical connector from the back of the tail light.
Tail light connector
Tail light Connector disconnected
Remove 1 8mm bolt from outside edge of tail light near wheel well. This is the reason we needed to remove the 2nd moulding piece.
External tail light bolt
Remove 3 bolts from inside of trunk holding the assembly. You can use you new assembly to get an idea of their positioning.
Tail light bolts 1
Tail light bolts 1
Tail light bolt 2
Tail light bolt 2
Release the 2 clips holding the assembly in
Pull assembly straight back to remove.
Tail light clip 1
Tail light clip 1
Tail light clip 2
Tail light clip 2
Removed light
Removed light
Step 6: Reinstall everything
Going in reverse order, reinstall everything you removed. When reinstalling the bumper remember to re connect the sensor cable and re mount it to its mount. 2 people will make this step easier but with some careful maneuvering you can do it solo. I also found the bumper clips along the side of the car like to bend down under the clips on the body and may need to be pulled up a bit to guide them in correctly.
Misbehaving clip
Misbehaving clip
Step 7: Congrats
You have completed your task, hopefully successfully. Grab a cold one and relax.
_______________________________
2015 S60 T5
2021 Polestar 2 LRDM PPP
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Thank you! This will be most helpful for others.
