I popped open my NAPA WIX Gold filter element and was pleased to see a new o-ring.
There was none on my canister, hmm.
I put the new one on and noticed there is a rubber ring in a groove of the canister, but it’s not round, and not smashed down - it’s clearly a rectangular section shape so that it’s flat and smooth on the outside. I thought, huh, do they both go on there? (I am the oil changer, so it’s my fault if it’s missing)
So I placed the o-ring down at the “shelf” at the bottom of the thread area and it screwed right in snug.
Square rubber ring - I don’t see this on parts diagrams
New o-ring -
Oil filter canister o-ring
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
That's not correct, your first picture the flattened seal needs to be removed and the new seal goes into the groove the old seal was in. Only one seal should be fitted
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 264 times
Correct, for what its worth once you have the new o-ring in the proper groove you can probably go a dozen oil changes without fitting a new one in, I usually throw the new one out after inspecting the old one. I use Volvo filters and they always come with a new ring.
2003 XC 70 (sold)
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
VERY interesting. So that seemingly perfect square ring is a mashed o-ring? It's so nice and square, like it was made that way. So that groove is where the new one goes?
I have screwed up. Wonder how much oil I'll dump out pulling it back off? At least it sits vertical.
Thanks guys! THAT's probably why it was wet....
- BlackBart
Fixed it.
You can see where I thought this looked like a manufactured, square profile "O" ring. Fits perfectly in the rectangular recess.
- Has thanked: 1853 times
- Been thanked: 1714 times
Maybe a different brand or incorrect seal was supplied at one point? That is definitely a rectangular section seal.
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
Every brand of oil filter I have used have had a round oring.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
