How to clean engine and transmission for leak diagnosis?
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
What is a good way to clean an oil soaked P80 engine and transmission before looking for leaks? I believe the Internet recommends power washing, but which sensitive or old components might that damage and how can they be protected? Which cleaning chemicals do you use? How do you catch the oil-laced rinse water from this job?
I've tried applying degreaser, scrubbing with sponges, then rinsing with minimal water from a spray bottle. After a painstaking effort, this removed maybe 40% of the oil, leaving the engine barely good enough for leak diagnosis. There must be a safer, easier way which approaches results like used car dealers or even show cars.
FireFox31
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
Take it to a self service car wash, along with a lot of quarters. I'd look for one with heated water and a degreaser. I've also taken my own degreaser, but some carwashes get funny about that.
Normally, I don't get to fussy with covering, protecting, or avoiding anything, but in our engine's stay away from the very top of the engine's as it's easy to get water in the plugs and it'll short your ignition until you get the water out. At home I'd spray it and suck the rinse water out with a shop vac.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
wahiddd
Year and Model: 2001 S40 2.0T
Post by wahiddd »
Purple Power is a life savers when it comes to degreasing any old auto part. Alternatively you can use what autoshops use, which is brake cleanear I think it's called
Has thanked: 1846 times
Been thanked: 1710 times
If you have a distributor, then zip-tie a bag around it to keep water out. I would avoid the ABS module and fuse boxes, but other than that go for it.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I'd avoid high pressure. It gets into places you don't want it. Degreaser, car wash degreaser, some scraping, rinse.
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
Remember dirt will collect on the underside also and spray underside as much as you can reach. What you wash off will stay out of your clothes, eyes and hair.
454cid
Post by 454cid »
scot850 wrote: 14 Aug 2024, 15:41 If you have a distributor, then zip-tie a bag around it to keep water out. I would avoid the ABS module and fuse boxes, but other than that go for it.
Our distributors are so simple, I disassembled mine and pressure washed the area.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
FireFox31
Post by FireFox31 »
Thanks, I'll try to cover these vulnerable areas and use low but firm pressure. I have some serious oil build up on many engines, especially in tough spots like under the intake and behind the crankshaft pulley. I want to build a water catch pan so I can do this cleaning on a lift. I wish there was a small power washer nozzle instead of the big metal wand.
I've heard steam cleaning can work without all the splashing and rinse water. I have a steamer so I'd like to try it. But I must keep it clean for interior work, thus must avoid oil splashing.
FireFox31
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Some use foil for easy shaping to cover the Cap & Rotor, Alternator or anything you deem sensitive electronics. I have washed many a cars with only two that I remembered stumbling.
The first was the 98 S70 T5 but I did manage to drive it home 7 miles from the car wash. I think moisture got into the distributor.
The second was the 00 S70 SE Base. I had left the cover off the coils and while washing water got into the hairline cracks in the coils. 3 of the necks were crumbling also and 1 or 2 were bad so went ahead and change them all.
5 Pcs Ignition Coils for 2000 Volvo S70
https://a-premium.com/product/5x-Igniti ... DZ5wchcJ0B
454cid
Post by 454cid »
I haven't watched all this video yet, but Mike is cleaning a very dirty Volvo engine compartment.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
