br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Both of my cars, as they approach 400km, are leaking oil. About 1L every 5000km.
Should I switch to 10W30 from 0W40? Or should I put some Lucas Oil Stabilizer in my next oil change?
04s60 2.4
04xc70 2.5t
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
br0dy519 wrote: 27 Aug 2024, 13:06 Both of my cars, as they approach 400km, are leaking oil. About 1L every 5000km.
Consumption or leaking? If leaking, where it's from would determine a potential band aid. If it were my car I would go with a 15W40 for summer and 5W40 for winter.
(EDIT: Again, depending on the leak a switch to Dino could be beneficial.)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
mounted a new tire on the rim ,
Has thanked: 1847 times
Been thanked: 1710 times
Funnily enough, with the close to 285,000km 02 XC70 I am working on, the owner says it uses about 1 liter/oil change. Mind you his changes are more like 8000km or more. I have 5W-40 so I was thinking of using that as it needs a change. Thanks for the suggestion!
br0dy519
Post by br0dy519 »
might start using Rotella instead of the mobil1 stuff then.
04s60 2.4
04xc70 2.5t
MoVolvos
Post by MoVolvos »
br0dy519 wrote: 28 Aug 2024, 14:23 might start using Rotella instead of the mobil1 stuff then.
Started using Mobil 1 in the mid 90's and stopped as I lost 3 or 4 head gaskets. Had to read it in the magazines back in the day. Tried the Mobil 1 0W40 a couple of years ago when Costco had a sale. The Volvo, Honda and Lexus didn't like it. Back to Rotella T6 after trying a bunch of oil in the last couple of years (a couple of others not shown). Cheap and no complaints from the cars.
br0dy519
Post by br0dy519 »
I'm certain I'm splitting hairs now, but does T4 or T6 matter? Cost doesn't really seem much better than what I get my Mobil1 on sale for.
04s60 2.4
04xc70 2.5t
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
br0dy519 wrote: 28 Aug 2024, 20:27 I'm certain I'm splitting hairs now, but does T4 or T6 matter? Cost doesn't really seem much better than what I get my Mobil1 on sale for.
Depends. IMO a conventional or semi-syn is fine for a car that does 3000-4000 mile change intervals and has trips long enough to get hot and keep sludge at bay.
If it is subjected to lots of short trips, synthetic is a better choice. Also allows a bit longer change intervals out to 5000 miles.
08 C702.5T (sold)
The non-Swedes:
We don't seem to get gasoline engine Rotella here. All I see are for diesel engines. I know there is a debate if you can use diesel engine oils on gasoline engines safely.
Krons
Post by Krons »
scot850 wrote: 29 Aug 2024, 17:23 We don't seem to get gasoline engine Rotella here. All I see are for diesel engines. I know there is a debate if you can use diesel engine oils on gasoline engines safely.
Rotella has a SN rating, so works fine for gasoline engines. Double check the bottle you get with your owners manual page.
08 C702.5T (sold)
The non-Swedes:
