Hi all,
2 months ago my -95 850 Turbo failed to start. I checked for fuel and spark and found i had no spark I replaced the cam sensor and ignition coil but still no spark, I tested the crank sensor and resistance is 290-ohms, there's batt power at the crank sensor connector and 5v ref. So I the cam and crank sensors are good and the coil is new, what else can cause a no spark issue? I checked for codes and got 111. I checked all fuses under the hood, all good. Someone Please Help.
No Spark with new components
gizmaster_1
- Year and Model: 850 Turbo 1995
- Has thanked: 5 times
- Been thanked: 3 times
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Ignition cap & rotor,main fuel injection relay(grey one) on fan shraud.
There is a possibility that you installed cam sensor wrong way since it can be installed both ways...wrong and right way.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1880 Views
Last post by Juan62
- 1577 Views
Last post by precopster
