07 Caliper Bolt Question
b4sennett
Year and Model: 2007 xc90
Has thanked: 2 times
Post by b4sennett »
Hello all,
I have a '07 XC90. I'm trying to remove the calipers and it has a weird bolt holding them on. It appears it should be a T55, but my T55 is too big and T50 is too small. I took a pic to get a better look at it and it is definitely different. Can anyone tell me what this is and what I need to do to remove it?
Thanks!
Been thanked: 472 times
Post by cn90 »
Do you have a zoom-out photo of the area of concern?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
b4sennett wrote: 15 Sep 2024, 09:33 Hello all,
Thanks!
The corrosion might be keeping the T55 from fully fitting properly. Try gently tapping it to see if it will go in fully.
Post by cn90 »
Those Internal Torx bolts hold the 2 halves of the caliper together. Don't touch these bolts when doing the usual brake job...
b4sennett
Post by b4sennett »
cn90 wrote: 16 Sep 2024, 14:50 Those Internal Torx bolts hold the 2 halves of the caliper together. Don't touch these bolts when doing the usual brake job...
Thank you...I'm clearly an idiot...I appreciate it!
Post by cn90 »
No worry, we all make mistakes.
Stay safe, support with jack stands etc
MoVolvos
Post by MoVolvos »
