jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
abscate wrote: 22 Sep 2024, 07:21 Spent about 30 minutes lube, heat, and hammer on axle shaft stuck in hub
Then to the right tool
30 seconds
10 ton hydraulic gear puller from Harbor Freight worked for me. Someone had filled the splines with some type of adhesive as if they were trying to fix a 99+ axle-ping on our 98. Then a complicated process involving using a chain wrench, two feet, both hands, a 20 inch pair of channel-locks, and all my body weight to get an M22 die started to repair the threads ruined by trying to hammer the axle out (despite threading an axle nut on).
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
Has thanked: 1836 times
Been thanked: 1709 times
Volvo used a glue type product to stop spline clicking when customers complained about it. Makes it a devil to remove and axle with that in place as you found out.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
So, I know I am just procrastinating and not doing the important jobs, but whatever. Put a small sub (Pioneer TS-WX010A) in the rear. For now I just wanted to see if it works and how good. First car I am doing some sort of speaker overhaul to. For me this is fine, and I think it will not be in the way back there. Didn't even fit under the seat as these typically should.
Now, someone already had power (split from the blower motor) and some other cables back there, so that made it easier. Still need to get the rca cable unter the rear carpet somewhere.
Edit: also replaced brake fluid, as it was noted as mostly bad last checkup.
850 T5-R '95 auto Image
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Rip Bosch distributor.
Has thanked: 1497 times
Been thanked: 3810 times
Are you finished with that distributor cap??
xanthefin
Post by xanthefin »
abscate wrote: 26 Sep 2024, 04:31 Are you finished with that distributor cap??
Its ex-distributor now. Signed papers.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Papers are signed, it's free for the taking now! Plus shipping cost, of course.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
I don't remember my distributor caps have had plastic on top of the contact.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
454cid wrote: 26 Sep 2024, 10:14 I don't remember my distributor caps have had plastic on top of the contact.
That was a special edition for the Finnish market.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
hausmeister
Regarding distributors, the last one I replaced (bosch) I tried to clean the contacts and it honestly looks pretty good and solid still. I kept it for a rainy day, but really - could it be reused for an extended period? Just curious, if the contacts are not worn out, are there other considerations?
(You know, keeping the ex as a spare ;) )
