Misfire?
reigox
Year and Model: 2004 v70
Has thanked: 2 times
Misfire?
Post by reigox »
the problem started after a 100km drive. While idling the engine is jerking/jumping after every 5 seconds or so.
When i give it like 70%-100% gas, then the car starts vibrating or jerking/jumping
460901111_7833118630121595_8650658408341209992_n.mp4
(1.01 MiB) Downloaded 10 times
reigox
Post by reigox »
engine is 2.5T, automatic gearbox
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
I would first inspect the coil packs and then spark plugs. Usually the first culprit.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
To me it sounds like one of exhaust valves are not sealing properly, it will burn soon. I had this sporadic chugging for a few months, then it finally burned. This when it quit:
It commonly happens around 220-250k miles (350-400k km over the Pond), thanks Volvo for switching hydraulic lifters to solid tappets.
You would need to rebuild the head. Perhaps, replace the piston rings, because it is so easy with the head off.
reigox
Post by reigox »
I forgot to mention, the car has a code aswell ''Catalyst System Efficiency Below Threshold (Bank 1)
Does that have something to do with the problem?
vtl
Post by vtl »
reigox wrote: 23 Sep 2024, 06:30 I forgot to mention, the car has a code aswell ''Catalyst System Efficiency Below Threshold (Bank 1)
Yes. There's unburnt fuel in exhaust that overruns catalyst's working capacity.
reigox
Post by reigox »
vtl wrote: 23 Sep 2024, 06:35
Can i drive it like this, and for how long?
vtl
Post by vtl »
reigox wrote: 23 Sep 2024, 06:37 Can i drive it like this, and for how long?
You can drive it like that until fixed. The longer you drive, the longer and more expensive fix would be ;)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
vtl wrote: 23 Sep 2024, 06:21
its commonly starting in mine but we hardly drive anywhere these days.
I've seen rebuilt heads for $800 online.
I think I'll do a compression test before dropping $1000+.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Any coil codes?
08 C702.5T (sold)
The non-Swedes:
