the problem started after a 100km drive. While idling the engine is jerking/jumping after every 5 seconds or so.
When i give it like 70%-100% gas, then the car starts vibrating or jerking/jumping
Misfire?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
To me it sounds like one of exhaust valves are not sealing properly, it will burn soon. I had this sporadic chugging for a few months, then it finally burned. This when it quit:
It commonly happens around 220-250k miles (350-400k km over the Pond), thanks Volvo for switching hydraulic lifters to solid tappets.
You would need to rebuild the head. Perhaps, replace the piston rings, because it is so easy with the head off.
vtl
Yes. There's unburnt fuel in exhaust that overruns catalyst's working capacity.reigox wrote: 23 Sep 2024, 06:30 I forgot to mention, the car has a code aswell ''Catalyst System Efficiency Below Threshold (Bank 1)
Does that have something to do with the problem?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
its commonly starting in mine but we hardly drive anywhere these days.vtl wrote: 23 Sep 2024, 06:21
I've seen rebuilt heads for $800 online.
I think I'll do a compression test before dropping $1000+.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Any coil codes?reigox wrote: 23 Sep 2024, 06:30 I forgot to mention, the car has a code aswell ''Catalyst System Efficiency Below Threshold (Bank 1)
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 19 Replies
- 10377 Views
Last post by Barledge
- 2554 Views
Last post by Ryanxr400
- 955 Views
Last post by stephansvolvo
- 8361 Views
Last post by 2008XC70
- 863 Views
