Concerned about car lift points
windsheardesigns
Year and Model: 1999 Volvo V70
Post by windsheardesigns »
Hello. I recently purchased a 1999 Volvo V70 AWD for the extremely low, almost fradulent price of $450 USD, and I have a question that's probably been answered but I can't seem to understand/figure out a straight answer.
I've seen different ideas and places on where to jack up the rear of this car and I don't feel safe picking an option unless I know, for 100% certain, that it's safe. (I will be getting under the car.)
Jackstands are self explanitory but I'm having trouble with where to jack the car up in the first place. I have included two photos of places I've tried and I need information on which to choose (or where else to go).
Rear
Rear
Front, left side
Front, left side
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Front is correct. That is the support, and the OE jack has a corresponding "u" shape to meet it.
I used the front subframe all the time, sometimes with wood to make a broad surface. Rear I don't know, I never had a P80 AWD. Someone will chime in who knows.
More:
viewtopic.php?p=261965#p261965
viewtopic.php?t=73284
Also -> Amazon link
Has thanked: 1506 times
Been thanked: 3820 times
Best place to jack the rear of a P80 XC (98 99 00) is the two round solid steel structures near the jack point
Picture here
windsheardesigns
abscate wrote: 16 Oct 2024, 20:43 Best place to jack the rear of a P80 XC (98 99 00) is the two round solid steel structures near the jack point
Picture here
Could you clarify and/or get pictures? They would be a massive help if you can. Thank you.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 89 times
Post by V50M66 »
windsheardesigns wrote: 17 Oct 2024, 04:41
Picture here
Forward of the rear wheels, you will see it clear as day when you look under the car. There are large circular protrusions where the rear trailing arms mount to the body. You want to jack it up using these.
In the front, use the triangle-shaped subframe mounting points and the rear of the front subframe
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
Has thanked: 1853 times
Been thanked: 1714 times
100% with V50M66 on this. I can' see if you have the little mudflaps just forward of the rear wheels mounted to the front trailing arm bracket that has been mentioned. It is that round metal part just in front of the rear wheels on an AWD car. Large bolt in the middle.
Under the rear where you show your jack on the rear subframe is another but less recommended spot due to balance issues.
Front as mentioned, the 'A' frame at the rear of the subframe.
As for jack support stands, I use the front subframe just behind the front wheels. At the rear is is a little more difficult. What I use is a stout piece of wood just forward of the rear jack point he mentioned, to spread the load. I use a piece of slim oak just large enough to cover the point contacts of the jack stand. There may be pictures still on my V70R rear subframe rebuild thread.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
someone on here had a factory jack support brake off because it was rusted. didn't look bad at all, but be careful with them.
I usually use the triangular plate that secures the front subframe to lift it, and in the rear that red arrowed spot pictured above.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
Clemens wrote: 18 Oct 2024, 15:57 someone on here had a factory jack support brake off because it was rusted. didn't look bad at all, but be careful with them.
I didn't post about it I think, but the drivers side jack point of my 850 was broken of, mostly from misuse of pre-owners I think. Had it welded back together at a shop.
On my s70 I used them all the time to jack up the whole side if the car in one go, no issues. So maybe inspect how solid they look b4 you do that.
Otherwise I agree on the mounting points of the subframes. Pinch weld is also marked on 2 locations on the bottom, but I never used that with a floor jack.
850 T5-R '95 auto Image
