The cracker was started as P2 2004+ (CEM-L) project.nikemen wrote: 22 Oct 2024, 18:08 Because of what it says in the code:I'm sorry, I'm trying to understand.Code: Select all
comment out for P2 CEM-L on the bench w/o DIM
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Yariy
- Year and Model: XC90
- Has thanked: 16 times
- Been thanked: 10 times
Hello! I'm new here. I have a CEM-B(Volvo V70 2003) from which I subtracted the 28F400 and want to change the configuration. The CEMB unit is disassembled. I use the CEMtool program of the respected T5Luke. The program shows the correct configuration and PIN code. I am trying to write the configuration using Dice to CEM-B, which is connected on the table and goes out for diagnostics, but the program responds with "wrong code". The PIN code is located at #6000. The CEMtool PIN code is determined correctly.
What am I doing wrong? Maybe the conditions for allowing access to the "Security access mode" are not met? The unit is connected on the table, but the ECU and the immobilizer antenna with the key are not connected, maybe this is the case? I recorded the CAN Bus parcels over the HS and LS bus. I see the package #000FFFFE 40 BE 12 24 32 38 21 94 from CEMtool to CEMB, what should be the answer?
Sorry for my poor English.
vtl
CEM on the bench needs nothing more to accept pin. What's your 6 bytes of pin code at #6000, and what is your CEM part number? Also when you read the flash chip, did you do byte swap to change endianness?Yariy wrote: 23 Oct 2024, 07:04 Hello! I'm new here. I have a CEM-B(Volvo V70 2003) from which I subtracted the 28F400 and want to change the configuration. The CEMB unit is disassembled. I use the CEMtool program of the respected T5Luke. The program shows the correct configuration and PIN code. I am trying to write the configuration using Dice to CEM-B, which is connected on the table and goes out for diagnostics, but the program responds with "wrong code". The PIN code is located at #6000. The CEMtool PIN code is determined correctly.
vtl
For you P/N the shuffle order is nr.2 in array:Yariy wrote: 23 Oct 2024, 09:46 Thanks for the reply. Yes, I do swap the large and small sequence numbers, but if I had made a mistake somewhere, the block would not have been diagnosed and the configuration would have been incorrect in CEMtool.
https://github.com/vtl/volvo-cem-cracke ... er.ino#L96
https://github.com/vtl/volvo-cem-cracke ... 85-L63C102
I.e. 5, 2, 1, 4, 0, 3
Shuffling your pin by hands give this:
Code: Select all
0 1 2 3 4 5 <- shuffle order
24 12 38 32 94 21 <- pin in flash
21 38 12 94 24 32 <- pin to send over CAN
Yariy
Thank you very much, I overlooked somewhere, reading this forum, mistakenly thought that the direct order was from 0 to 5. Then it is unclear why CEMtool issues a direct order as in a dump compatible with the order of VIN reflection.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I am curious for input. Remember how I said those overwrites seemed like bugs? What if they are not?
Notice how the code writes r5 to the solenoids flags. But a few instructions later it overwrites it with another flag.
@(r0,r3) means r0[r3] = value
nikemen
- Year and Model: 2012 C30 T5
- Has thanked: 3 times
Well, I did that (first commenting the line out, then deleting it). Here's what I got:vtl wrote: 22 Oct 2024, 05:42 Almost any digital electric circuit needs a common ground between its parts.
Try it with door open, but without key. With key in position 0, 1 or 2. Remove CEM_PN_AUTODETECT: https://github.com/vtl/volvo-cem-cracke ... er.ino#L14 (in that case you may need to tweak LS/HS speed according to what your vehicle has: https://github.com/vtl/volvo-cem-cracke ... .ino#L1354)
Code: Select all
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
PIN bytes to measure: 3
CAN low-speed init done.
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
Part Number: 0
Unknown CEM part number 0. Don't know what to do.
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Thanks in advance!
vtl
Teensy does not see any CAN traffic on the high speed bus. Check your circuit, I guess? The code is supposed to print any CAN message it receives when waiting for the part number response. You should be getting something if hw is right.nikemen wrote: 23 Oct 2024, 15:20Well, I did that (first commenting the line out, then deleting it). Here's what I got:vtl wrote: 22 Oct 2024, 05:42 Almost any digital electric circuit needs a common ground between its parts.
Would it be any use to go and look for the CEM part number under the dash?Code: Select all
CPU Frequency: 180000000 Execution Rate: 180 cycles/us PIN bytes to measure: 3 CAN low-speed init done. CAN high-speed init done. Putting all ECUs into programming mode. CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00 CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00 Reading part number from ECU 0x50 on CAN_HS CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00 Part Number: 0 Unknown CEM part number 0. Don't know what to do. Resetting all ECUs. CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00 CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
Thanks in advance!
- 9380 Views
Last post by RickHaleParker
- 9398 Views
- 27 Replies
- 29076 Views
Last post by cn90
- 10 Replies
- 10919 Views
Last post by jonesg
- 6032 Views
