WTB 745 fuse panel (eBay find, entire harness) Topic is solved
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
'86 Turbo. Recent arrival, thought it needed a fuel pump relay, found this Surprise instead.
I'll try to do a search on a year range, this one is a keeper ( I think ) so I'd rather not do a workaround.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
Do you think turbo if different from non turbo? I should have good fuse block for non turbo 1990 745.
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
volvolugnut wrote: 07 Nov 2024, 17:26 Do you think turbo if different from non turbo? I should have good fuse block for non turbo 1990 745.
they use the same fusebox 1347424
Where is the fuse box hidden? I bought the 745 for parts and am not familiar with it. Is it in driver side foot well?
I need to find it and see if mine is in better condition than yours.
foggydogg
Post by foggydogg »
volvolugnut wrote: 07 Nov 2024, 19:27 Where is the fuse box hidden? I bought the 745 for parts and am not familiar with it. Is it in driver side foot well?
On this one it's hidden behind the ash tray/cigar lighter; pulling the ash tray exposes the panel, the lighter has to come out to see the relays behind it.
On the '90 760 I got stuck with it's behind a plastic cover on the end of the drivers' side dash.
I will try to look at in the next couple days. It is raining today and car is at another location.
Do you need the relays?
foggydogg
Post by foggydogg »
volvolugnut wrote: 08 Nov 2024, 10:24 I will try to look at in the next couple days. It is raining today and car is at another location.
The relay stuff appears to be intact, and everything else on the car seems to work. It even ran, which is a mystery, but I presume the fuse had enough of a tenuous grip on what was left of the socket to fire the pump relay.
I don't want to take it apart outside, so I haven't dug any deeper.
The trick to getting the cigar lighter part out is the small square trim piece around the lighter; it pops off exposing two screws ( mine had a non-intuitive aftermarket radio installed, many surprises in that area.)
Thanks for checking this out.
foggydogg
Post by foggydogg »
This is what it looks like in the wild,
Found one on eBay - but it's in England, and I don't think Dr. Abscate is on a parts run this trip.
lrock
Post by lrock »
i visited a local yard yesterday and had a look after i grabbed what i went for and none there matched (LKQ hawkins point)
lrock
Post by lrock »
just figured out how to do interchange lookup in vida, here ya go.
