First of all Good Day!
Second, i own a 2014 V60 D6 AWD Plugin Hybrid. After an unlucky meeting with a little pole the abs vaccum pump was broken and the car got a DTC "Brake Pedal Characteristic have changed. Service required!" . The guys at the workshop didn;t notice the broken pump and tried to calibrate. That failed and the error changed to "DTSC Service Required!" . Now everything about DTSC is disabled and the car woun;t switch to electric anymore.
The abs vacuum pump is repaired, and everything looks good on the car and the calibration still fails.
Do you have any ideeas or tips?
C1018 - Regenerative Braking Calibration/Parameter Memory Failure
- 701 Views
Last post by draser
- 15 Replies
- 2541 Views
Last post by draser
- 1581 Views
Last post by mrscullini
- 1470 Views
Last post by Acknar
- 997 Views
