CE light on
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
CE light on
Post by lcc014 »
Yesterday, CE light turned on while driving on highway. Car was driving fine with the light ON. I checked the DTC code this morning, A2, 232. It meant : Long term fuel trim, idling. For the time being, I erased the code and turned off the CE light. I will drive the car tomorrow and see whether the CE light will come back or not.
So is this code related to O2 sensor or else ? My wagon is NA.
Thanks,
Ching-Ho Cheng
Has thanked: 1853 times
Been thanked: 1714 times
Check the hose elbow on the end of the intake manifold at the power steering pump end has not split/ broken off.
Smoke test or check with brake cleaner to see if any vacuum hose leaks.
Lastly O2 sensors.
lcc014
Post by lcc014 »
Thank you for the information. Does the NA 850 has that elbow hose too ? I thought that only turbo 850 has the elbow hose of the intake manifold.
I will take a look tomorrow.
Ching-Ho Cheng
Good question now you mention it! I recall replacing one on one of my older P80's. Now can't recall if it was the 93 850 GLT or the 98 V70 XC.
I'll try to check too, although a quick look under the hood will be quicker.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Yes...n/a have it...at least later models...'96 & '97.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
lcc014
Post by lcc014 »
misha wrote: 19 Dec 2024, 01:51 Yes...n/a have it...at least later models...'96 & '97.
Okay, my wagon is 95. Will check that.
Ching-Ho Cheng
Has thanked: 1507 times
Been thanked: 3824 times
Probably a vacuum leak somewhere. Can you read fuel trims with your current tools/ instrument set?
lcc014
Post by lcc014 »
abscate wrote: 20 Dec 2024, 01:15 Probably a vacuum leak somewhere. Can you read fuel trims with your current tools/ instrument set?
I checked the vacuum elbow this morning and found nothing in that area. So far, CE light is still off after 1 day of driving.
Since my wagon is 1995 model so it only provides the OBD-I interface in front of the CPU box. How to read the fuel trims ?
misha
Post by misha »
No live data readings with OBDI.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
lcc014
Post by lcc014 »
misha wrote: 20 Dec 2024, 13:30 No live data readings with OBDI.
Alright, hope for the best that CE light stays off..... :shock:
