Cross nut on front strut--does it matter which way?
Turbolena
Year and Model: 850 Turbo Wagon 1994
Has thanked: 2 times
Post by Turbolena »
I am wondering if I need to pull the strut and flip that cross nut around . It is laying flat. Does anybody know if the cross is up or down really matters?
I was rushing the job as I am trying to finish many car repairs and projects rather than move all those parts.
1994 850 Turbo Wagon
2006 V70R
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
the flat part goes up against the large washer. You can see the outline on the said washer. Its not possible to use the tool if its the wrong way..
2001 XC70 factory M58
2002 XC70 auto (parts car)
Turbolena
Post by Turbolena »
The tool tightened it as far as it would go down, with no play...so the cross goes down against the seat, or the cross lays against the upper washer? just to clarify. Thanks
2006 V70R
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
FCP has video showing cross nut position.
darrylrobert
cross lays against the upper washer.
Been thanked: 504 times
Post by cn90 »
With car on the ground and spring compressed, I think you can safely remove and flip the cross nut in situ.
I use a pair of right-angle pliers...
SwedishMadeFunBrick
Year and Model: Saffron 1998 V70R
Has thanked: 11 times
Been thanked: 4 times
Post by SwedishMadeFunBrick »
cn90 wrote: 22 May 2020, 08:29 With car on the ground and spring compressed, I think you can safely remove and flip the cross nut in situ.
You can do it while it's still in the car? I need to do this on my 98 v70r(mine aren't flipped,instead, for some reason I cannot figure out, I guess I decided to replace my front struts and maybe use what came with the struts? Not a cross nut just a lock nut of sorts. I hope it came with the struts at least I really don't remember).
Anyway, I got the cross nuts and want to install them this way but also just read that you can't do it in the car lest the shock protrude or some such.
Has thanked: 311 times
Been thanked: 817 times
Yes, in-car is no problem. Don't close the hood and go for a drive during the job, though :)
This thread talks about the top nut viewtopic.php?t=78217 but you can remove the cross nut too. Basically, the body of the car is serving as a huge, spring compressor.
