SRSmessage '02 xc70
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
SRSmessage '02 xc70
Post by Faust »
Looking at another Volvo, an '02 xc70. It has the SRS hazard message on. Working without VIDA is there any practical method to find the fault?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
I would want to talk to the previous owner, what did they do to cause it.
WHat counts is whether it can be cleared.
Has thanked: 1500 times
Been thanked: 3812 times
Faust wrote: 20 Jan 2025, 11:29 Looking at another Volvo, an '02 xc70. It has the SRS hazard message on. Working without VIDA is there any practical method to find the fault?
A good high end reader will give you the SRS codes which will point you to the component in question but VIDA is king or Queen in our house.
Autel 800 series or the tablet will read and clear codes from the air bag module
jonesg
Post by jonesg »
In MA theres a slew of volvos for sale , none have srs problems,
For me its a deal breaker, considering they could get the SRS light turned off for less than $150, so why didn't they.
johnspi
Year and Model: 2005 XC70
Post by johnspi »
Greetings: Previous owner on my 2005 XC70 had the drivers side VIC (Volvo Inflatable Curtain) deployed and just cut the wires, did not have repaired. I need help, looking to add the 2.5K ohm resistor without pulling the console apart to shut off the SRS light.
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
I would suggest to go to a local u-pull yard and get yourself a proper airbag(may need to become a buddy-buddy with sales person ir wrap it in other big part since i believe airbags are not permitted for resale technically..but you can always buy one for "project" or off the car that is for parts by owner). Also go get your recall for driver's airbag after that at dealer for free.
jonesg
Post by jonesg »
johnspi wrote: 25 Aug 2025, 13:58 Greetings: Previous owner on my 2005 XC70 had the drivers side VIC (Volvo Inflatable Curtain) deployed and just cut the wires, did not have repaired. I need help, looking to add the 2.5K ohm resistor without pulling the console apart to shut off the SRS light.
I would try locating the wires, either in the A or B pillar, disconnect the battery and discharge phantom voltage.
An interactive circuit diagram in allData might help.
You can also try this resource, I only glanced at it but it might give you enough to start looking..
http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf
Think about it, if the bag blew then the wires would be right there, I would have chopped them at that point rather than go looking for the SRS controller.... which I believe is under the seat (drivers seat?).
If it is in the console thats no big deal, a few screws, had to remove mine to install new rear brake cables.
It looks like the wiring is in the B pillar. Maybe they pulled the impact sensor.
jonesg
Post by jonesg »
johnspi
Post by johnspi »
I'm just about there. Today I pulled off the pillar next to the windshield, the connections are right there. Just need to get the right color codes. I'll let you how it turns out.
jonesg
Post by jonesg »
johnspi wrote: 02 Oct 2025, 18:50 I'm just about there. Today I pulled off the pillar next to the windshield, the connections are right there. Just need to get the right color codes. I'll let you how it turns out.
circuit diagrams should be here,
https://charm.li/Volvo/2004/V70%20L5-2. ... Diagnosis/
