BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
My temporary visqueen and Gorilla tape to keep what’s left of the grease in my CV joint got cold and is now making a flap flap flap noise. Too cold and snowy to fix it outside.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
Failing mounts and bushing season continues. 10-years and 70k+ miles later, the pair of Meyle HD LCA may need an upgrade.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
xHeart wrote: 31 Jan 2025, 06:55 Failing mounts and bushing season continues. 10-years and 70k+ miles later, the pair of Meyle HD LCA may need an upgrade.
10 years and 93k miles ago I replaced just the bushings, with OE. May need to inspect them after winter, but they were still OK last fall.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
BlackBart wrote: 28 Jan 2025, 21:52 My temporary visqueen and Gorilla tape to keep what’s left of the grease in my CV joint got cold and is now making a flap flap flap noise. Too cold and snowy to fix it outside.
they sell collars that go around the original cv boot .
Still too cold though. 17F here, funny ... it feels like 16F.
vtl
Post by vtl »
jonesg wrote: 31 Jan 2025, 17:25 they sell collars that go around the original cv boot .
All I can do in this weather is pulling a DEM fuse, so driveshaft's dead u-joint is not loaded. Big Yotas are parked for month+ now: they don't heat up as well as old Volvo does. Plus all that road salt... Old Volvo does not care about it. Mostly.
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
Not a problem - it's a feature. Remember playing cards noise makers on bicycle spokes?
volvolugnutr
djdadcore
Year and Model: 2003 XC70
Post by djdadcore »
I’m trying to fix my headlight control module in my 03 xc70. Reflowed solder and checked all the connections and metered everything, it’s functional but it won’t come back intermittently. Someone I know mentioned the large capacitors might be dry and struggling to get started until the car is warmed up.
Capacitors have a working life and often fail. They are easy to replace if you can identify the rating and can solder.
BlackBart
Post by BlackBart »
We're having a mini-blizzard over here, mostly due to one of those North Dakota cold blasts spilling over the mountains. Hard-packed slippery streets, deep drifting snow. I'm getting the odd sensation I am not getting any AWD. You know that FWD feeling with wheel spin and the front end wandering sideways? - it's not grabbing and moving forward. And it has new Blizzak snows on it.
I'm not sure yet, I need to find an empty place I can goose it and turn and see if the rear is kicking in, or if it's delayed somehow.
And the garage is of course filled with old cars and loose engines and axles, so I can't pull it in.
BlackBart wrote: 05 Feb 2025, 12:54 We're having a mini-blizzard over here, mostly due to one of those North Dakota cold blasts spilling over the mountains. Hard-packed slippery streets, deep drifting snow. I'm getting the odd sensation I am not getting any AWD. You know that FWD feeling with wheel spin and the front end wandering sideways? - it's not grabbing and moving forward. And it has new Blizzak snows on it.
I have a garage and two shops and I have to work on my cars outside. sigh.
