Sway Bar End Link Removal (2004 V70)
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Another good reason to replace these with with OEM Volvo ones, they come with a hex in the middle of the ball shaft so you can hold it from turning and will last about three times longer than the aftermarket ones.
2003 XC 70 (sold)
- Been thanked: 504 times
Actually, I found the 16-mm easier to work with bc the Torx/Allen is usually not enough to counter hold the rusty nuts in salted area. In the BMW photo above, the end link is Lemforder brand, so it is OEM.
PS: the nut is usually Stover type, so it is tough to turn.
Also, if you have no access to local bicycle shops, the eBay has these 16-mm wrench for $8-$10...
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
xHeart wrote: 03 Feb 2025, 07:53this, or a prybar to brace the rear side and hit it witjh the impact, or just chop it off with an angle grinder.cn90 wrote: 03 Feb 2025, 07:30
I use an open end wrench from Harbor Freight - PITTSBURGH; it has the right depth. It slides over the counter hold with slight resistance against the rubber boot - fits. Clean and spray with lubricant first -- it always works!
- BobbyC777
- Year and Model: V70 2.5T, 2004
- Has thanked: 27 times
- Been thanked: 7 times
I ordered a super thin 16x18 mm open end (Duratech) from Amazon for < $8.cn90 wrote: 03 Feb 2025, 15:52 This is a photo from my 1998 BMW 528i end link....you can see the thin 16-mm wrench there...
https://www.amazon.com/dp/B09G6HQW7L?re ... title&th=1
- BobbyC777
I plan to order the Lemförder (OE) end links. FCP sells the pair for $57. The Gen-u-INE Volvo units go for $188.Blacklab467 wrote: 03 Feb 2025, 17:45 Another good reason to replace these with with OEM Volvo ones, they come with a hex in the middle of the ball shaft so you can hold it from turning and will last about three times longer than the aftermarket ones.
- Has thanked: 2197 times
- Been thanked: 1851 times
I recommend not using an impact on these nuts unless you have a wrench on the rear. I could not understand why mine failed so regularly. It turns out when the car used to go to the dealer for front end work, they used impacts and just kept them spinning until they came loose. This melts the nylon cup and makes the joint loose! Personally I prefer the nut version on the back as the Torx ends are useless after a couple of years in the winter salt.
- BobbyC777
I purchased a thin open end wrench to help hold the inner nut to allow me to remove the sway bar end link (aftermarket). My standard wrench was about 9 mm at the head while the new was is 3 mm. I purchased the thin wrench (chrome) from Amazon for $8. Bicycle "cone" wrenches are another thin wrench option. Fingers crossed!
Comparison of standard & thin wrenches
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Keep in mind if you're replacing the links with new ones you can get more medieval with the removal method, vice grips for counter hold and impact wrench or angle grinder to cut of the old ones as erikv11 mentioned. Nice to have the thin wrench on hand but if the nut and threads are in bad shape the thin wrenches don't always hold.BobbyC777 wrote: 05 Feb 2025, 22:16 I purchased a thin open end wrench to help hold the inner nut to allow me to remove the sway bar end link (aftermarket). My standard wrench was about 9 mm at the head while the new was is 3 mm. I purchased the thin wrench (chrome) from Amazon for $8. Bicycle "cone" wrenches are another thin wrench option. Fingers crossed!
- Been thanked: 4064 times
Once I have the grinder out, and a nasty northeast rusty bolt in sight, I can’t resist …..
- 14 Replies
- 3370 Views
Last post by subzerocarfanatic
- 25 Replies
- 2086 Views
Last post by 5rivers
- 34 Replies
- 9280 Views
Last post by E Showell
- 846 Views
Last post by FCPEURO
- 1442 Views
