2000 XC 16T Turbo Upgrade W/ Hilton tune
Darrin95
Year and Model: 2000 V70 XC
Post by Darrin95 »
I'm currently rebuilding my XC due to a burnt exhaust valve in cylinder 3. I'm doing the works to it, timing kit, head gasket kit, PCV box, head bolts, axle seals, a bunch. I noticed the turbo leaking and wanted to see about upgrading so I jumped down the rabbit hole and started researching. I finally came across Hilton which gave me most of the answers I was looking for. Yes I can upgrade to a 16T Turbo, they recommended a stage 3 tune, green Injectors (which I believe my car already has, I have to double check), when looking on there site stage 3 states it's for P1, and P2 platforms but mine is a P80 platform.
Also I'm not looking to make this alot faster then stock I'm just looking for a tune to handle the new turbo. When clicking 2000- XC70 no tune shows up either only under V70. I wasn't really told which cable to use either the dice or the VROOMFLASH J2534 Cable. Does anyone have any knowledge and advice they can share with me?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
In this case I'd try Swedespeed. They're performance folks ( hence the name ) and they have a section just for '98 - 2000.
1999 V70 GLT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
If you do want to make this go a lot faster than stock, here are some ideas by @bmdubya1198 viewtopic.php?f=1&t=92407
Also -> Amazon link
