98 non turbo running rich when cold
grottu
Year and Model: 1998 V70 Wagon
Post by grottu »
Hello.
Have this car as a spare since a month....i can smell (and see) thats running rich when cold, everything goes away when gets up to temp.
Zero starting issues in -30 or +20, idles great, nothing out of ordinary, no check engine or codes.
MAF sensor is clean and fine.....what to check next? oxygen sensors?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
You do realize they ARE programmed to run rich while starting up. Cold engines need more fuel. Granted it should stabilize way before operating temp.
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
coolant temp sensor might be off. don't replace with Chinesium, OE only.
Unless you drive alot of short trips I wouldn't worry about it too much
1996 855 R,
2010 V70 D5,
grottu
Post by grottu »
Yeah I know that it should run rich at startup, choke thing, just smell a bit too much for my liking.
Have to crawl underneath, maybe someone gutted out cat and spaced second sensor, it would look exactly like that....reality of no inspections
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
grottu wrote: 28 Mar 2025, 08:19 Yeah I know that it should run rich at startup, choke thing, just smell a bit too much for my liking.
Even a basic scan tool should be able to read the signal from the coolant temperature sensor; if the connector has some age related issues sometimes the unplug/plug back trick can get it to feel better.
Agree with the above, if you replace that sensor use an OEM brand, and as always, avoid anything URO anywhere, any time.
grottu
Post by grottu »
foggydogg wrote: 28 Mar 2025, 09:00
Good hint, will clean connector and test it with multimeter at cold and after 5 minutes of running. Found resistance chart.
