Hello.
Have this car as a spare since a month....i can smell (and see) thats running rich when cold, everything goes away when gets up to temp.
Zero starting issues in -30 or +20, idles great, nothing out of ordinary, no check engine or codes.
MAF sensor is clean and fine.....what to check next? oxygen sensors?
98 non turbo running rich when cold
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
coolant temp sensor might be off. don't replace with Chinesium, OE only.
Unless you drive alot of short trips I wouldn't worry about it too much
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Yeah I know that it should run rich at startup, choke thing, just smell a bit too much for my liking.
Have to crawl underneath, maybe someone gutted out cat and spaced second sensor, it would look exactly like that....reality of no inspections
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Even a basic scan tool should be able to read the signal from the coolant temperature sensor; if the connector has some age related issues sometimes the unplug/plug back trick can get it to feel better.grottu wrote: 28 Mar 2025, 08:19 Yeah I know that it should run rich at startup, choke thing, just smell a bit too much for my liking.
Agree with the above, if you replace that sensor use an OEM brand, and as always, avoid anything URO anywhere, any time.
Good hint, will clean connector and test it with multimeter at cold and after 5 minutes of running. Found resistance chart.foggydogg wrote: 28 Mar 2025, 09:00Even a basic scan tool should be able to read the signal from the coolant temperature sensor; if the connector has some age related issues sometimes the unplug/plug back trick can get it to feel better.grottu wrote: 28 Mar 2025, 08:19 Yeah I know that it should run rich at startup, choke thing, just smell a bit too much for my liking.
- 814 Views
Last post by misha
- 19 Replies
- 5646 Views
Last post by Sommerfeldt
- 14 Replies
- 3155 Views
Last post by Kuhnboy
- 18 Replies
- 4369 Views
- 17 Replies
- 3502 Views
Last post by John850GLT
