Those of you with mechanical throttles... 9189149
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
I'm not sure of this applies to the turbo cars, or just the NA. The plastic cover that goes over the bracket and throttle pulley assembly, do you use it, or have it removed? I removed mine, maybe for cleaning the engine bay, and never re-installed it. I still have it, and am tempted to re-install it, but can never come up with a good reason why, and it's always seemed extraneous to me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I bought a brand new one because mine was missing when I got the car.
Does it make any meaningful difference ? Nope. Just looks a bit less messy
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
454 - it's either for looks or to keep fingers from getting pinched in there, I've never figured out. Mine has been off for some time, as I was in there working on things. It might have been an aesthetic thing to make it look a little "slicker" instead of exposed cables and pully.
454cid
Post by 454cid »
BlackBart wrote: 14 May 2025, 15:44 454 - it's either for looks or to keep fingers from getting pinched in there, I've never figured out. Mine has been off for some time, as I was in there working on things. It might have been an esthetic thing to make it look a little "slicker" instead of exposed cables and pully.
Yeah, I figure it's a precursor to the modern engine cover.... I keep removing and installing the cover on my Cadillac.
On the 850, I've thought about removing that bracket, and refinishing it, in some manner. The car needs other things that I'm already not doing, so that little project won't happen any time soon.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2653 times
Been thanked: 1247 times
Post by matthew1 »
I took it off my 850 T one day also and never put it back. Same with the turbo heat shield. And the engine cover.
Also -> Amazon link
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
'98 V70, it's sitting in a box. Unless one is extremely stupid, it likely has no real purpose. =)
Has thanked: 1504 times
Been thanked: 3817 times
If you can’t find your 9189149 and need a new one….because Matt pays me by the part number
Posted
Thst#5 screw isn’t available but I think it’s a common t25 torx metal screw
Has thanked: 1847 times
Been thanked: 1710 times
I thought it was a T25 threaded bolt with washer for the screw.
Point made above, " unless you are incredibly stupid...." , enough said. I'd suggest the cover gives some protection to the throttle mechanism. Is it essential no.
johnnyfd
Year and Model: 850T wagon 1996
Post by johnnyfd »
Just like manufacturers have had to take measures to avoid the danger of a stuck open throttle due to throttle body icing, this is likely another safety measure.
The throttle spring has a lot of return force on it (to ensure it will close once released) and would likely be able to close itself regardless but it is possible if something with the right mass were to be forcefully pulled into the space between the front of the throttle pulley and whatever is in front of it by the strong spring tension of the throttle, it could get wedged and prevent the throttle from closing.
I know on my car I have had to reattach the hood insulation/lining and it is possible, though unlikely, that some of the liner could contact and then get pulled down into that gap as I mentioned before or could simply get tangled in the pulley and cable.
I'd rather just keep it in place than be concerned with those potentially dangerous issues.
YMMV especially if you keep a super clean and organized engine bay.
454cid
Post by 454cid »
scot850 wrote: 17 May 2025, 08:19 I thought it was a T25 threaded bolt with washer for the screw.
I think mine did have a separate washer which made me think it might not be original. I keep forgetting to look for it, when I go out to the garage.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
