There is a lot of mediocre quality lead in the supply stream for batteries, but in hot climates I don’t think buying oem will get you much. Abby’s 99 is running a 2018 up here in cool climates.
- Has thanked: 1504 times
- Been thanked: 3817 times
- Has thanked: 1846 times
- Been thanked: 1710 times
I find batteries are for the most part lasting well. The proviso is not having them run too low, and where possible (and it is) to check the battery fluid level and keep it topped up. Many new batteries no longer have the facility to do this unfortunately. I changed the 10 year old battery in our son's 2006 XC70 (well we think it was that old as no date code and fitted when bought), not because it was bad, but as it was 10 years old. In winters here the deep cold when parked outdoors can kill a battery that was otherwise showing no issues.
I believe heat can kill batteries. Looking at the overheated one on the C30 project is a good case in point. Maintaining your charging system and checking grounds so the alternator charges correctly is also a good maintenance for longer battery life as well as watching your battery leads are good.
Just looked at the replacement battery from Volvo for the C30. I was near $500 CDN!! That is total nonsense.
https://www.volvocarstorontoparts.ca/p/ ... 72241.html
I can get a battery from Costco with better warranty for $200.
Good luck out there!
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
There are only a handful - three or four - major battery builders in the States these days. Clarios (ne Johnson Controls) is the biggest player,
East Penn/Deka and Exide. Like the restaurant trades ordering pies ala carte from Sysco calling out the type of flour and specifying lard in the crust &c., retailers like Interstate and NAPA can fiddle with the internal bits of car batteries to fit their price point and warranty models.
Sometimes the only play is to buy something affordable from a local vendor and hope for the best.
- Has thanked: 304 times
- Been thanked: 517 times
Yep, which is why I stick with Walmart for my batteries. Auto parts stores charge an insane premium. Same with oil.foggydogg wrote: ↑27 May 2025, 23:51 There are only a handful - three or four - major battery builders in the States these days. Clarios (ne Johnson Controls) is the biggest player,
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
You guys jinxed me because I just had to change the battery on the XC. It went from taking slightly longer to start to one day just being totally dead in about a week or two. Thankfully it was somewhere I could get a jump, and drove straight to Walmart and bought the top step battery before they became AGM. Still couldn't get the hold-down to seat properly.
When I was walking around the car letting it run, I noticed I could hear the fuel pump for the first time I can remember. At least I think it is, hard to isolate under the car. It is approaching 200k miles but now I feel stupid for ever letting the tank get low. Hopefully it's something else, as the information on the AWD pumps is pretty convoluted not even accounting for doing the job.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 129 times
The hold down on my 850 works fine, but on my S70 it would not. The 850 has an H5 (DIN) battery, and I think the S70 had an BCI/SAE? group-size battery.
https://www.walmart.com/ip/EverStart-Ma ... A/20531541
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
These cars are supposed to use either H5 or H6 batteries.
jsrnsis
Mine says it's a group xx battery, but the part number is h6. Walmart didn't have any batteries marked as only h6 on the shelves.454cid wrote: ↑29 May 2025, 10:22The hold down on my 850 works fine, but on my S70 it would not. The 850 has an H5 (DIN) battery, and I think the S70 had an BCI/SAE? group-size battery.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
Possibly a H5 = Group 47 battery. A H6, the other version is a Group 48. Both should fit and lock in on a P80.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Had to replace the second tire she's done this to in the past 3-4 months.
