Power steering rack leak
SS2115
Year and Model: 850 SE 1995
Post by SS2115 »
Is it possible to replace the end seal of a power steering rack while the rack is still in the car?
I have one end with quite a leak, but the other end and the pinion shaft are bone dry, clean and dusty. Its only the drivers end that is filling up the boot and leaking past the big end of the boot.
It looks possible and with easy access of the wheel removed, but I don't know exactly what is involved for the Volvo 850 or if special tools are required.
I was hoping there might be some information or advice of someone who has tried it as I saw in a couple of forums it can be done but not how and what was required to have ready on hand.
Yes - I can appreciate that its best to remove and replace everything, but for the short life the car has remaining and its low value, it just not worth the expense or hassle of taking the rack out for swap or overhaul.
Hope someone can advise.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Look through this result set... I remember an in situ approach but I don't recall if it was for P2 Volvos.
search.php?keywords=steering+rack+in+situ
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
If it's on the driver (or pinion) side, then it's the inner rack seal that's gone. That's not removable without pulling the entire rack out of the housing.
I posted up an old PDF of a RHD steering rack rebuild when I went through redoing the rack in my '97. That'll show you what you need to know.
You can find it HERE
SS2115
Post by SS2115 »
Thanks Chuck W.
Unfortunately, our leak is indeed the drivers side (same side as the steering shaft /pinion). Damn!
SS2115
Post by SS2115 »
Hi again Chuck W.
Was hoping I could clear up some items in your instructions if I may. *Great by the way.
2.1: removing the steering gear.
I'm okay down to point 9 where you add information.
I have an engine support beam (between the fenders) so my understanding was to support the engine and release just the rear engine mount and the "end" mount (next to the crankshaft pulley at "front" of the engine), after which undo the front subframe bolts about 15 - 20mm and then lower the rear subframe by jack till it stops and get enough room to manhandle the rack out.
I can pull the bolt on the top engine torque rod as well as release the bottom one if necessary.
But your discussing placing jack under the transmission and using it to lower the entire subframe with engine fully attached I think your saying? Thats a lot of weight on the subframe? Unstable balanced on the jack as well?
Have I misunderstood the instructions perhaps?
Been thanked: 4067 times
I lowered the subframe with the engine and transmission held up with the fender to fender brace. There are a lot more disconnects if you want to lower the engine and transmission too.
You can disconnect the steering column in the car and get the no-longer-available universal joint off the rack if you need to replace it or grease it on your bench, much easier than disconnecting the rusted splines underneath
Chuck W
Post by Chuck W »
SS2115 wrote: 19 Jun 2025, 22:58 Hi again Chuck W.
Those are not my instructions in that PDF. It's an OLD one I've had for a while and can't find the original source. The thread I posted it in covers my removal and rebuild of the steering rack. The PDF was more to help with a breakdown of disassembly, etc.
I left the engine and trans in place, and used a support beam to hold them. I removed the entire subframe, with the rack attached. It's easier to work with. I've removed racks, etc with the subframe supported but dropped a bit, and it's a PITA. Dropping the subframe is just easier for me.
