Has thanked: 1506 times
Been thanked: 3822 times
Sveedy wrote: 14 Jul 2025, 12:14 ^ If Abscate Breakers is in business, I'm still looking for a few parts for the V70 rebuild. Specifically the turn signal stalk and a cup holder ( of course ) if you have them.
We’ve got a new candidate en route. Will advise. I think I consumed Shaggs on Karla but I could be wrong
bw711
Year and Model: 1999 S70GLT
Post by bw711 »
I replaced the filler neck retaining sleeve (both halves) on my 99 S70GLT.
The lower half was almost completely gone.
Each half cost $39 on fcp. Genuine Volvo, no aftermarket available.
The new parts look much less sturdy that the old.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
Wow, they only sell them in halves? That's unfortunate.
melmaclifeform
Year and Model: 2000 S70 GLT SE
Has thanked: 2 times
Been thanked: 7 times
Post by melmaclifeform »
Placing more orders so I can drive the S70 up to Virginia today. Also quoting concrete so a driveway can be put in to work on my cars at my new place.
Does anyone know the part number for the nut that goes into the top engine mount on 99+ S70s? I can't find it on any parts diagrams and my car has somehow lost its.
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
melmaclifeform wrote: 15 Jul 2025, 10:06 Placing more orders so I can drive the S70 up to Virginia today. Also quoting concrete so a driveway can be put in to work on my cars at my new place.
Torque rod running from top of engine to firewall?
https://www.volvopartswebstore.com/show ... veLine=482
melmaclifeform
abscate wrote: 15 Jul 2025, 10:35
The one I'm referring to is part 48 in that diagram. The one with 4 bolts that bolt into the head. I'd go to the hardware store for a replacement, but I'm trying to bump a small FCP order to free shipping, haha.
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
I saw 3 cars with turn signal stock still intact at my local junkyard.
The drinks manufacturer here switched from stubby cans to long thin cans.
Need to find someone to 3d model and print a drink holder for the new cans.
1/2 a shitbox V70 1998 2.5 NA
melmaclifeform wrote: 15 Jul 2025, 10:53
I just noticed that diagram is wrong for the 1999. Yes, I’m a bit 99 Savant
The 1999s don’t use the stay on the left car/ rear engine engine mount , that’s only -1998 part 33 shouldn’t be there on a 1999
melmaclifeform
abscate wrote: 15 Jul 2025, 17:35
Send 'em an email and they might correct it :lol:
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
volvolugnut wrote: 12 Jul 2025, 15:27
850 LPT wrote: 12 Jul 2025, 15:10 Replaced the fuel pump on the 98' S70 yesterday after confirming that there is no fuel pressure. The car still won't start. And yes, I dropped in another good pump relay before.
Did you give the pump time to prime?
A full tank may help priming.
Thank you. I tried cranking 3 times and for pretty long. It never took that long when I replaced these pumps on P80 non canbus cars in the past. Tank is actually full.
Today I took some time to look further into this. First I confirmed that there was power at the pump. I never knew that the pump only gets power when cranking, I thought it would come on when the ignition is in pos 2. But maybe canbus P80 does that, not sure.
So power was there but I was not able to hear or feel the pump. Then I took the pump out again and put power directly to it, and there was nothing. Looks like a bad brand new pump. I looked over the installation instructions again, because this was the first time I replaced the actual pump in an assembly. Can't see anything wrong though.
I need to get this car moving again soon, so maybe I can temporarily use the pump from the non running 99' S70. Need to get confirmation if that's the same pump.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
