Pre vs post facelift body parts
snugani
Year and Model: 1996 855 turbo
Post by snugani »
Recently my beloved pre facelift 850 was t- boned by a pickup truck. Thankfully nobody was hurt, it actually took the impact very well. I just bought a 96 wagon that's pretty nice overall. I'm wondering if anyone here knows if the pre facelift fenders and doors will fit on the post facelift. I can see the trim is different but I'm hoping that can be swapped, I'm not sure if they attach any differently though.
I just can't decide if it’s worth it to go and pull the fender and doors off my old car vs just touching up a few spots that bother me on the new one. I would also have to swap the door cards as the new one has the charcoal interior and my old one had tan.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
They will fit perfectly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1853 times
Been thanked: 1712 times
Hey Misha, my memory is not so good on this. As I recall the 93-4 cars had different headlights, and I think the strip under the headlights were different. If you are transferring everything over then will these need swapped too?
misha
Post by misha »
He asked about fenders and doors Neil...they are interchangeable.
Headlights,tail lights and front position lights/blinkers are different.
Bumpers are also different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
I actually doubt they will fit. The early headlights are larger and accordingly are the turn signal units (they are definitely larger, I couldn't fit them in my 94-96 cars). Therefore the cutout in the front fenders has to be larger on the pre facelift cars.
I have a few fenders in storage, I can measure the next time I'm there but most certainly they are different.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
misha
Post by misha »
Cutouts for turn signals on pre facelift cars are the same as for later cars and they are not the problem because later cars have bigger trims which goes under them to fill the gap for smaller turn signal lights.
Compare a fender from early and later cars and you will see that they are the same...except the side trims which are smaller on early cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Post by Clemens »
I'll give it a try, Misha.
I just wonder why I couldn't get these '92 turn signal units to fit in the '96.
Summer: 1996 855 R
Donor: 1995 854 10V
misha
Post by misha »
Probably because of a carrier/frame which holds headlights,turn signals,radiators and horns.
Openings for them are bigger for early cars since headlights and turn signals are bigger.
You can swap whole front end (headlights,turn signals,bumper)between early and later cars as long as you have matched front carrier/frame for the car.
This:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
I have a little dent on front passenger fender and found locally a perfect matched color fender from early car to swap it when i have time.
I also had doubts will it fit...but when you compare it closely...it is the same...minus a narrower trim...which can also be swapped from my fender.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Post by Clemens »
Now I'm glad I pulled all parts off that 92 I parted out 2 yrs ago...
Summer: 1996 855 R
Donor: 1995 854 10V
