I think, you did it on CEM with 835CPU.
Try decrypted eep dump from 855 in attach, can you see anything?
It is from a cem with a M30855FWUGP cpu.Treur wrote: 14 Aug 2025, 22:38 I think, you did it on CEM with 835CPU.
eep_855_dec.zip
I'm looking at this dump now and I have a very strong feeling that I decrypted it with the wrong algorithm. 835 has 61 byte code, and 855, as far as I remember, has 2048 bytes. And it seems to me that I decrypted it with the algorithm from 835porcupine7655 wrote: 15 Aug 2025, 10:00 It is from a cem with a M30855FWUGP cpu.
Your dump is different than mine. The immo records are not stored in same way. Rest of data looks like it is.
In mine all stored data is in duplets with crc after each. In this dump the immo data is stored in a different way.
Can you share the flash as well? I can't promise that I take a look how it is stored but if I have it probability increases.
It will also be easier to have the raw eeprom dump too see what area is nothing stored at.
Don't think you have used wrong algo. There is a lot of records with correct crc and they have a duplicate. If you used wrong algo this will not show up. BUT the area where I have immo data in my cem it finds no records.Treur wrote: 15 Aug 2025, 10:36I'm looking at this dump now and I have a very strong feeling that I decrypted it with the wrong algorithm. 835 has 61 byte code, and 855, as far as I remember, has 2048 bytes. And it seems to me that I decrypted it with the algorithm from 835porcupine7655 wrote: 15 Aug 2025, 10:00 It is from a cem with a M30855FWUGP cpu.
Code: Select all
Records:
018--01f: 000000000000 CRC b475 OK
020--027: 000000000000 CRC b475 OK
034--03d: ba7d84920dbabfb8 CRC df89 OK
03e--047: ba7d84920dbabfb8 CRC df89 OK
1b4--1b7: 0010 CRC d0f2 OK
1b8--1bb: 0010 CRC d0f2 OK
228--22f: 000000000200 CRC 0446 OK
230--237: 000000000200 CRC 0446 OK
238--23b: 0000 CRC 51e2 OK
23c--23f: 0000 CRC 51e2 OK
240--25b: 0101c5df03000000000000000000001000000080040000003180 CRC 5973 OK
25c--277: 0101c5df03000000000000000000001000000080040000003180 CRC 5973 OK
278--293: 0100800000000000000000000000000000000000000000000000 CRC ccb9 OK
294--2af: 0100800000000000000000000000000000000000000000000000 CRC ccb9 OK
2b0--2cb: 000000000000001bf17e72fe00005c0000000000000000000000 CRC d837 OK
2cc--2e7: 000000000000001bf17e72fe00005c0000000000000000000000 CRC d837 OK
2e8--303: 001bf17f31fe00005d0000000000000000000000081bf17f50fe CRC 0db3 OK
304--31f: 001bf17f31fe00005d0000000000000000000000081bf17f50fe CRC 0db3 OK
320--33b: 00005d0000000000000000000000001bf17f60fe00005c000000 CRC f0d6 OK
33c--357: 00005d0000000000000000000000001bf17f60fe00005c000000 CRC f0d6 OK
358--373: 000000000000000002001bf17ff7fe00005c0000000000000000 CRC 004b OK
374--38f: 000000000000000002001bf17ff7fe00005c0000000000000000 CRC 004b OK
390--3ab: 0000001bf188cbfe00005a00000000000000000000000b0a1bf1 CRC efa2 OK
3ac--3c7: 0000001bf188cbfe00005a00000000000000000000000b0a1bf1 CRC efa2 OK
3c8--3e3: 8c3cfe000059000000000000000000000a1bf18f99fe00005900 CRC 5b51 OK
3e4--3ff: 8c3cfe000059000000000000000000000a1bf18f99fe00005900 CRC 5b51 OK
400--41b: 000000000000000000000a1bf18ccefe00005900000000000000 CRC 270d OK
41c--437: 000000000000000000000a1bf18ccefe00005900000000000000 CRC 270d OK
438--453: 000000000a1bf18ccffe00005900000000000000000000000a1b CRC e54c OK
454--46f: 000000000a1bf18ccffe00005900000000000000000000000a1b CRC e54c OK
470--48b: f18cd0fe00005900000000000000000000000a1bf18cd1fe0000 CRC 6c11 OK
48c--4a7: f18cd0fe00005900000000000000000000000a1bf18cd1fe0000 CRC 6c11 OK
4a8--4c3: 5900000000000000000000000a1bf18cd2fe0000590000000000 CRC d6e5 OK
4c4--4df: 5900000000000000000000000a1bf18cd2fe0000590000000000 CRC d6e5 OK
504--509: f39df11b CRC 51e1 OK
50a--50f: f39df11b CRC 51e1 OK
510--517: 000000000000 CRC b475 OK
518--51f: 000000000000 CRC b475 OK
538--553: 0000000000000a1bf18eaffe0000590000000000000000000000 CRC 1653 OK
554--56f: 0000000000000a1bf18eaffe0000590000000000000000000000 CRC 1653 OK
570--573: 0100 CRC 89fb OK
574--577: 0100 CRC 89fb OK
578--57b: 5000 CRC a631 OK
57c--57f: 5000 CRC a631 OK
580--583: 0101 CRC 00ea OK
584--587: 0101 CRC 00ea OK
590--5ab: 0e010203040506070e08090a0b0c0d000014001400b00000000f CRC 3b1e OK
5ac--5c7: 0e010203040506070e08090a0b0c0d000014001400b00000000f CRC 3b1e OK
60c--627: 000d00b50007000f0004008f0007000f000400920000000f0004 CRC 31b3 OK
628--643: 000d00b50007000f0004008f0007000f000400920000000f0004 CRC 31b3 OK
644--65f: 0000000e000e000000b40007000a000200020009000a000100d7 CRC a5fb OK
660--67b: 0000000e000e000000b40007000a000200020009000a000100d7 CRC a5fb OK
67c--697: 0007000a0002000f0007000a000200100007000a000200110007 CRC 599e OK
698--6b3: 0007000a0002000f0007000a000200100007000a000200110007 CRC 599e OK
6b4--6cf: 000a000200bf0007000a000200c00009000a0001006c00000000 CRC 465e OK
6d0--6eb: 000a000200bf0007000a000200c00009000a0001006c00000000 CRC 465e OK
6f8--713: 0000000000000000000000000100000000000000000000000000 CRC 9aca OK
714--72f: 0000000000000000000000000100000000000000000000000000 CRC 9aca OK
Unmapped:
000--017: 64a52a14f92f734403feff6bfe86ae512cfb12b02879f2a4
028--033: 276070002746250ebd4d30f5
048--1b3: 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
1bc--227: 09396478e1a650d984b7beda1cf9006be33be1e55e9da0c34444641ff61bc93e251760102f7531518e8387c65f37da6d79f9d3f5c8172e201551cd45aa09396478d2a850d984b78dd41cf95189e33bb00784bf838b4444641ef69303f7067bbf1d1a204d518ed265c65f6638
4e0--503: 3c66fd512a28d3ca03841c4896d1c2b295f497bd0eff8247e5e2dbb661c47b3c4ed3129d
520--537: 3abfe68189268539c69ed9cbbb9cfd9eb506f4894ceee9d3
588--58f: 73ee5c480939359a
5c8--60b: aa09688678d2f9b2d8843e76d51c70aad188ece34cef53acf4b2a1d1f697f4df6392ef2a888fb5d90eab145321bd7ff07e71f9d3d1e117a6cc8160e60daa2d116478f4e6
6ec--6f7: e904d28eb8ff010094017952
730--7ff: f86df880ab5429fe18ba2272f9af4b018905932250880e57303f90338f71296e7d0d2a4b2f04b7463bfe5c5a600dda7fc087f66aab241af7217c4a0df0f165f097bc433ee900a23b6be0b65219911e88394b93164f2926892a9669317162123554371cae5f22e745427816c164db9cee72b23d03ee3864521ae7e672e79fb44a37e009ab3363ebbd59129a168030429a1f46212e862599663e796a1b3c5d3e15a65729ec4e49731ec96dd295e77bba3534d90f536522dfdf4bdea68d720fdb32900858d385602ba32fb9087aa520791e
I got almost same result.Treur wrote: 15 Aug 2025, 13:25 And the algorithm is really was wrong, I received a couple of Eproms and decrypted via IO-Terminal looks normal))) So now I need to write an algorithm for 855. I already found the key.
CEM 93C86 EEPROM dec_ori.zip
I fixed the encryption algorithm and got -
Synchro: 746368207449
Crypto: 4AC0D73EE37CF551856C4892
Key pin: 730998
Key 1: C81AB88C
Key 2: C81AA475
Key 3: 8D300F5E
Key 4: AA8ED34F
Key 5: 121C920E
Key 6: 8C92CEB1
Code: Select all
Records:
018--01f: 000070867026 CRC 3441 OK
020--027: 000070867026 CRC 3441 OK
034--03d: e36bfdb1e0ef7812 CRC d763 OK
03e--047: e36bfdb1e0ef7812 CRC d763 OK
048--04b: 2000 CRC 62c1 OK
04c--04f: 2000 CRC 62c1 OK
134--13b: 746368207449 CRC 002b OK
13c--143: 746368207449 CRC 002b OK
144--151: 4ac0d73ee37cf551856c4892 CRC 0f93 OK
152--15f: 4ac0d73ee37cf551856c4892 CRC 0f93 OK
160--165: 73099800 CRC 383a OK
166--16b: 73099800 CRC 383a OK
16c--171: c81ab88c CRC 179c OK
172--177: c81ab88c CRC 179c OK
178--17d: c81aa475 CRC 68ca OK
17e--183: c81aa475 CRC 68ca OK
184--189: 8d300f5e CRC 4f16 OK
18a--18f: 8d300f5e CRC 4f16 OK
190--195: aa8ed34f CRC f7a3 OK
196--19b: aa8ed34f CRC f7a3 OK
1b4--1b7: 9089 CRC c5e2 OK
1b8--1bb: 9089 CRC c5e2 OK
1bc--1c1: 03000200 CRC 4e18 OK
1c2--1c7: 03000200 CRC 4e18 OK
1c8--1cb: 0000 CRC 51e2 OK
1cc--1cf: 0000 CRC 51e2 OK
1d0--1f3: 2b977026000000000000000000000000000000000000000000000000000000000100 CRC ec77 OK
1f4--217: 2b977026000000000000000000000000000000000000000000000000000000000100 CRC ec77 OK
220--223: 0000 CRC 51e2 OK
224--227: 0000 CRC 51e2 OK
228--22f: 000000000000 CRC b475 OK
230--237: 000000000000 CRC b475 OK
240--25b: 0101000000080008000000000000000800000000108000000008 CRC 218c OK
25c--277: 0101000000080008000000000000000800000000108000000008 CRC 218c OK
278--293: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK
294--2af: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK
2b0--2cb: 0000000000000d25946de9510c2572054b6e01a400379a000000 CRC c146 OK
2cc--2e7: 0000000000000d25946de9510c2572054b6e01a400379a000000 CRC c146 OK
2e8--302: 00000c2594ce4f50001f5f054b6e01013e204b08000000000d CRC 25fc OK
304--31e: 00000c2594ce4f50001f5f054b6e01013e204b08000000000d CRC 25fc OK
320--33b: 94d4ab510c2073054b6e019300010a00000000000025ec174053 CRC 152a OK
33c--357: 94d4ab510c2073054b6e019300010a00000000000025ec174053 CRC 152a OK
358--373: 0c1665054c26019300010a00000000000d261831ee4d0c146f05 CRC da14 OK
374--38f: 0c1665054c26019300010a00000000000d261831ee4d0c146f05 CRC da14 OK
390--3ab: 4c7c645500010a0000000000002671bac2fe000064054d630191 CRC cdce OK
3ac--3c7: 4c7c645500010a0000000000002671bac2fe000064054d630191 CRC cdce OK
3c8--3e3: 00010a00000000000c2547b517fe00005d054a92019100010a00 CRC 6714 OK
3e4--3ff: 00010a00000000000c2547b517fe00005d054a92019100010a00 CRC 6714 OK
400--41b: 000000000c2547b518fe00005d054a92019500010a0000000000 CRC 9038 OK
41c--437: 000000000c2547b518fe00005d054a92019500010a0000000000 CRC 9038 OK
438--453: 0d2547d8c1530c2172054a9201a800002a00000000000d2551d2 CRC ee1d OK
454--46f: 0d2547d8c1530c2172054a9201a800002a00000000000d2551d2 CRC ee1d OK
470--48b: 27520c4b73054abe019500404a0000ff8e000d2551d22f520c4b CRC 993f OK
48c--4a7: 27520c4b73054abe019500404a0000ff8e000d2551d22f520c4b CRC 993f OK
4a8--4c3: 74054abe019000404a0000ff7e070d2551d3da510c4b69054abe CRC 6a38 OK
4c4--4df: 74054abe019000404a0000ff7e070d2551d3da510c4b69054abe CRC 6a38 OK
4e0--4e5: 634d0500 CRC ab35 OK
4e6--4eb: 634d0500 CRC ab35 OK
4ec--4f3: 8df8b13e0000 CRC dd6b OK
4f4--4fb: 8df8b13e0000 CRC dd6b OK
504--509: 93ba7126 CRC 2191 OK
50a--50f: 93ba7126 CRC 2191 OK
510--517: eb6563267902 CRC 6030 OK
518--51f: eb6563267902 CRC 6030 OK
538--553: 01b300058a00000000000d257ae5794c0c1271054b295f500005 CRC e3d7 OK
554--56f: 01b300058a00000000000d257ae5794c0c1271054b295f500005 CRC e3d7 OK
570--573: 0113 CRC 93d9 OK
574--577: 0113 CRC 93d9 OK
580--583: 0001 CRC d8f3 OK
584--587: 0001 CRC d8f3 OK
590--5ab: 8a000000000000258fcf09520c1f64054b670000001600000000 CRC 8f9c OK
5ac--5c7: 8a000000000000258fcf09520c1f64054b670000001600000000 CRC 8f9c OK
5c8--5cb: 0000 CRC 51e2 OK
5cc--5cf: 0000 CRC 51e2 OK
5d0--5d3: 0100 CRC 89fb OK
5d4--5d7: 0100 CRC 89fb OK
5d8--5db: 0100 CRC 89fb OK
5dc--5df: 0100 CRC 89fb OK
5f8--601: e9270000d4110000 CRC 823c OK
602--60b: e9270000d4110000 CRC 823c OK
60c--627: 00000601020304050600000000000000000300d9008e001b0002 CRC 5b43 OK
628--643: 00000601020304050600000000000000000300d9008e001b0002 CRC 5b43 OK
644--65f: 00d8008d006b000400d8006f002b00a500a5000000940066008c CRC 548b OK
660--67b: 00d8008d006b000400d8006f002b00a500a5000000940066008c CRC 548b OK
67c--697: 0002009f00000000000000bb003e003e00000011003e003e0000 CRC 182e OK
698--6b3: 0002009f00000000000000bb003e003e00000011003e003e0000 CRC 182e OK
6b4--6cf: 00120002003a0025002b00310031000000170031003100000016 CRC fea1 OK
6d0--6eb: 00120002003a0025002b00310031000000170031003100000016 CRC fea1 OK
6ec--6f1: 01000000 CRC 8812 OK
6f2--6f7: 01000000 CRC 8812 OK
6f8--713: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK
714--72f: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK
768--783: c027090000000000000000000000000000000000000001004800 CRC 0d62 OK
784--79f: c027090000000000000000000000000000000000000001004800 CRC 0d62 OK
7a0--7bb: 0031003100000037000b000b0000009f00030003000000940000 CRC faab OK
7bc--7d7: 0031003100000037000b000b0000009f00030003000000940000 CRC faab OK
7e4--7e9: 00080000 CRC f1c8 OK
7ea--7ef: 00080000 CRC f1c8 OK
Unmapped:
000--017: 8c0e9bd06c760d32cd70835e660650f934773485a4a4d4bf
028--033: a97f6c9bc8722e21af32ad17
050--133: 8cadacdcb072741ba981a711711aa52d48f1f8f425a2746493c17b2728a63aa50049b0a8a8a276a1bfe39d1f8ac17e641f21de63904c741441e825662293b2b3c3a86a6d02b098be096901be3653eae0ec3cbb6d7d8ad963303fb12db20841b9a1a1ab7fa9b7e8961481ca766c1628d76a99447c1b4ee72a692a9bbbbacaa163650abb93b5026209b63f5ae3e9e534b35a4abdee54080788148b317881999a9044928cd0ae2db8f34f552e10e855a67b432376de135013a28382f19a585e3183ab8c3b5b308f0762d4ded203845242b4e75d010e801c803a738a9292984d9b85d9a725b0
19c--1b3: 121c920e912b629b84848e5a8c92ceb133a6ed514b300df2
218--21f: e579e65d14edf5f5
303--303: 00
31f--31f: 00
4fc--503: 04d00618443bb92c
520--537: c7ac139bf9404a469710c6d72073c9959a148b14aee71e06
588--58f: cd9831fcbffd4c6d
5e0--5f7: 7aadbd4a19a3fff071ed72c8817860616bbf69772b55d441
730--767: 8458600055fc31723e8faeafdfb476711eac84a215751da22a4ff6fcf020a7716196c57f242ba539a61c55adb5b5bf6bbda3fc820095de62
7d8--7e3: ac79afb1ed931184f04c562d
7f0--7ff: a58485f59e5d5b3486ae883f58338c04
This dump have only 4 keysporcupine7655 wrote: 16 Aug 2025, 13:35I got almost same result.Treur wrote: 15 Aug 2025, 13:25 And the algorithm is really was wrong, I received a couple of Eproms and decrypted via IO-Terminal looks normal))) So now I need to write an algorithm for 855. I already found the key.
Key pin: 730998
Key 1: C81AB88C
Key 2: C81AA475
Key 3: 8D300F5E
Key 4: AA8ED34F
Key 5: 121C920E
Key 6: 8C92CEB1Only difference is that Key5 and Key6 is in what my script marks as "unmapped" area e.g they don't have correct crc or is not duplicated.Code: Select all
Records: 018--01f: 000070867026 CRC 3441 OK 020--027: 000070867026 CRC 3441 OK 034--03d: e36bfdb1e0ef7812 CRC d763 OK 03e--047: e36bfdb1e0ef7812 CRC d763 OK 048--04b: 2000 CRC 62c1 OK 04c--04f: 2000 CRC 62c1 OK 134--13b: 746368207449 CRC 002b OK 13c--143: 746368207449 CRC 002b OK 144--151: 4ac0d73ee37cf551856c4892 CRC 0f93 OK 152--15f: 4ac0d73ee37cf551856c4892 CRC 0f93 OK 160--165: 73099800 CRC 383a OK 166--16b: 73099800 CRC 383a OK 16c--171: c81ab88c CRC 179c OK 172--177: c81ab88c CRC 179c OK 178--17d: c81aa475 CRC 68ca OK 17e--183: c81aa475 CRC 68ca OK 184--189: 8d300f5e CRC 4f16 OK 18a--18f: 8d300f5e CRC 4f16 OK 190--195: aa8ed34f CRC f7a3 OK 196--19b: aa8ed34f CRC f7a3 OK 1b4--1b7: 9089 CRC c5e2 OK 1b8--1bb: 9089 CRC c5e2 OK 1bc--1c1: 03000200 CRC 4e18 OK 1c2--1c7: 03000200 CRC 4e18 OK 1c8--1cb: 0000 CRC 51e2 OK 1cc--1cf: 0000 CRC 51e2 OK 1d0--1f3: 2b977026000000000000000000000000000000000000000000000000000000000100 CRC ec77 OK 1f4--217: 2b977026000000000000000000000000000000000000000000000000000000000100 CRC ec77 OK 220--223: 0000 CRC 51e2 OK 224--227: 0000 CRC 51e2 OK 228--22f: 000000000000 CRC b475 OK 230--237: 000000000000 CRC b475 OK 238--23b: 0000 CRC 51e2 OK 23c--23f: 0000 CRC 51e2 OK 240--25b: 0101000000080008000000000000000800000000108000000008 CRC 218c OK 25c--277: 0101000000080008000000000000000800000000108000000008 CRC 218c OK 278--293: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK 294--2af: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK 2b0--2cb: 0000000000000d25946de9510c2572054b6e01a400379a000000 CRC c146 OK 2cc--2e7: 0000000000000d25946de9510c2572054b6e01a400379a000000 CRC c146 OK 2e8--302: 00000c2594ce4f50001f5f054b6e01013e204b08000000000d CRC 25fc OK 304--31e: 00000c2594ce4f50001f5f054b6e01013e204b08000000000d CRC 25fc OK 320--33b: 94d4ab510c2073054b6e019300010a00000000000025ec174053 CRC 152a OK 33c--357: 94d4ab510c2073054b6e019300010a00000000000025ec174053 CRC 152a OK 358--373: 0c1665054c26019300010a00000000000d261831ee4d0c146f05 CRC da14 OK 374--38f: 0c1665054c26019300010a00000000000d261831ee4d0c146f05 CRC da14 OK 390--3ab: 4c7c645500010a0000000000002671bac2fe000064054d630191 CRC cdce OK 3ac--3c7: 4c7c645500010a0000000000002671bac2fe000064054d630191 CRC cdce OK 3c8--3e3: 00010a00000000000c2547b517fe00005d054a92019100010a00 CRC 6714 OK 3e4--3ff: 00010a00000000000c2547b517fe00005d054a92019100010a00 CRC 6714 OK 400--41b: 000000000c2547b518fe00005d054a92019500010a0000000000 CRC 9038 OK 41c--437: 000000000c2547b518fe00005d054a92019500010a0000000000 CRC 9038 OK 438--453: 0d2547d8c1530c2172054a9201a800002a00000000000d2551d2 CRC ee1d OK 454--46f: 0d2547d8c1530c2172054a9201a800002a00000000000d2551d2 CRC ee1d OK 470--48b: 27520c4b73054abe019500404a0000ff8e000d2551d22f520c4b CRC 993f OK 48c--4a7: 27520c4b73054abe019500404a0000ff8e000d2551d22f520c4b CRC 993f OK 4a8--4c3: 74054abe019000404a0000ff7e070d2551d3da510c4b69054abe CRC 6a38 OK 4c4--4df: 74054abe019000404a0000ff7e070d2551d3da510c4b69054abe CRC 6a38 OK 4e0--4e5: 634d0500 CRC ab35 OK 4e6--4eb: 634d0500 CRC ab35 OK 4ec--4f3: 8df8b13e0000 CRC dd6b OK 4f4--4fb: 8df8b13e0000 CRC dd6b OK 504--509: 93ba7126 CRC 2191 OK 50a--50f: 93ba7126 CRC 2191 OK 510--517: eb6563267902 CRC 6030 OK 518--51f: eb6563267902 CRC 6030 OK 538--553: 01b300058a00000000000d257ae5794c0c1271054b295f500005 CRC e3d7 OK 554--56f: 01b300058a00000000000d257ae5794c0c1271054b295f500005 CRC e3d7 OK 570--573: 0113 CRC 93d9 OK 574--577: 0113 CRC 93d9 OK 578--57b: 5000 CRC a631 OK 57c--57f: 5000 CRC a631 OK 580--583: 0001 CRC d8f3 OK 584--587: 0001 CRC d8f3 OK 590--5ab: 8a000000000000258fcf09520c1f64054b670000001600000000 CRC 8f9c OK 5ac--5c7: 8a000000000000258fcf09520c1f64054b670000001600000000 CRC 8f9c OK 5c8--5cb: 0000 CRC 51e2 OK 5cc--5cf: 0000 CRC 51e2 OK 5d0--5d3: 0100 CRC 89fb OK 5d4--5d7: 0100 CRC 89fb OK 5d8--5db: 0100 CRC 89fb OK 5dc--5df: 0100 CRC 89fb OK 5f8--601: e9270000d4110000 CRC 823c OK 602--60b: e9270000d4110000 CRC 823c OK 60c--627: 00000601020304050600000000000000000300d9008e001b0002 CRC 5b43 OK 628--643: 00000601020304050600000000000000000300d9008e001b0002 CRC 5b43 OK 644--65f: 00d8008d006b000400d8006f002b00a500a5000000940066008c CRC 548b OK 660--67b: 00d8008d006b000400d8006f002b00a500a5000000940066008c CRC 548b OK 67c--697: 0002009f00000000000000bb003e003e00000011003e003e0000 CRC 182e OK 698--6b3: 0002009f00000000000000bb003e003e00000011003e003e0000 CRC 182e OK 6b4--6cf: 00120002003a0025002b00310031000000170031003100000016 CRC fea1 OK 6d0--6eb: 00120002003a0025002b00310031000000170031003100000016 CRC fea1 OK 6ec--6f1: 01000000 CRC 8812 OK 6f2--6f7: 01000000 CRC 8812 OK 6f8--713: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK 714--72f: 0000000000000000000000000000000000000000000000000000 CRC 70b4 OK 768--783: c027090000000000000000000000000000000000000001004800 CRC 0d62 OK 784--79f: c027090000000000000000000000000000000000000001004800 CRC 0d62 OK 7a0--7bb: 0031003100000037000b000b0000009f00030003000000940000 CRC faab OK 7bc--7d7: 0031003100000037000b000b0000009f00030003000000940000 CRC faab OK 7e4--7e9: 00080000 CRC f1c8 OK 7ea--7ef: 00080000 CRC f1c8 OK Unmapped: 000--017: 8c0e9bd06c760d32cd70835e660650f934773485a4a4d4bf 028--033: a97f6c9bc8722e21af32ad17 050--133: 8cadacdcb072741ba981a711711aa52d48f1f8f425a2746493c17b2728a63aa50049b0a8a8a276a1bfe39d1f8ac17e641f21de63904c741441e825662293b2b3c3a86a6d02b098be096901be3653eae0ec3cbb6d7d8ad963303fb12db20841b9a1a1ab7fa9b7e8961481ca766c1628d76a99447c1b4ee72a692a9bbbbacaa163650abb93b5026209b63f5ae3e9e534b35a4abdee54080788148b317881999a9044928cd0ae2db8f34f552e10e855a67b432376de135013a28382f19a585e3183ab8c3b5b308f0762d4ded203845242b4e75d010e801c803a738a9292984d9b85d9a725b0 19c--1b3: 121c920e912b629b84848e5a8c92ceb133a6ed514b300df2 218--21f: e579e65d14edf5f5 303--303: 00 31f--31f: 00 4fc--503: 04d00618443bb92c 520--537: c7ac139bf9404a469710c6d72073c9959a148b14aee71e06 588--58f: cd9831fcbffd4c6d 5e0--5f7: 7aadbd4a19a3fff071ed72c8817860616bbf69772b55d441 730--767: 8458600055fc31723e8faeafdfb476711eac84a215751da22a4ff6fcf020a7716196c57f242ba539a61c55adb5b5bf6bbda3fc820095de62 7d8--7e3: ac79afb1ed931184f04c562d 7f0--7ff: a58485f59e5d5b3486ae883f58338c04
If I shall guess is that are never written so they are all 0xff in raw encrypted eeprom.
In my dump I had only two keys defined, all other was 0xff in raw file. DHA gave id all 0 if readout.
What do you see printed on the serial console?ObliviousOrange wrote: 16 Aug 2025, 21:13 Hello everyone. New to this forum and new to messing with car software. I'm having trouble getting the CEM PIN out of my 2011 C30 though, which I wanted for VDASH.
I got a Teensy 4.0, two SN65HVD230DR transceivers, and a buck converter. I successfully uploaded the code to the teensy, and only changed the code to work with this super tiny OLED screen I have on hand.
I've been too lazy to wait for shipping of more electronics stuff, so to connect to the OBD I used alligator clips and the ends of paperclips since i didn't have any other wires thick enough for a snug fit. As far as i could figure, it seems to have a workable connection.
No PCB used here, just a breadboard. I've double-checked the wiring many times now. 20250816_195258.jpg
What happened is that I kept getting a loop of "initializing" on the OLED after plugging everything in. switching some wires on the RX/TX for the U3 transceiver made it say "unknown CEM, exiting" which i assume is better. I'd also get a CAN_LS error if I unplugged U5 which might be a good sign?
After getting nothing after a lot of messing around, I tried deleting the CM_PIN_AUTODETECT line as suggested in here for P1s. Then when I tried plugging it in my car made a loud click noise, lights turned off, and the clock reset (but was otherwise okay). It would still loop on initializing and every time the screen flashed the car would click again. Very concerning.
At this point I've thrown my hands up, idk what else I should be trying. I'm still trying to learn all this, any help would be appreciated. And I expect a lot of what I've said to sound like nonsense to anyone with experience so thanks for your patience.
