Our car was towed last week; upon picking it up at the tow yard in Denver, it would only move 20 feet before the engine stalled.
I ordered a new MAF from Penguin Parts and installed it, but the same issue with stalling persisted. Two possible issues from
\reading forum posts. Always use a Bosch MAF. There is probably an issue with a vacuum leak, because a hose is missing from
the pipe downstream from the MAF, as shown it a picture. The underside picture of the engine doesn't show any obvious destinations for where to attach the missing hose. If someone has a suggestion, I'm open to it. Just in case the open port is a problem I can try buying a cover for it.
1998 Volvo V70XC replaced MAF (non-Bosch), drivability issues (stalling out)
rocky_mtn_man
- Year and Model: XC70 1998
Look under hood on the right side for a sticker with the vacuum hose routing. They vary between models amd engines in a given year, so you need your diagram. That might be the fuel pressure regulator vacuum supply, needed
- Has thanked: 311 times
- Been thanked: 817 times
Yes it goes to the fuel pressure regulator but check your sticker to be sure.
See bullet point #3 in this post: viewtopic.php?t=63615
Here is my 1998 turbo sticker.
- Has thanked: 987 times
- Been thanked: 1075 times
No turbo sticker found.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
What happens if you unplug the MAF entirely? Should still start but run really rough.
- Has thanked: 2856 times
- Been thanked: 1332 times
@rocky_mtn_man this might match your XC70 https://www.matthewsvolvosite.com/vacuum-lines/
Its a tough, demanding crowd here....
viewtopic.php?p=669472#p669472
Old guys with little else to do......abscate wrote: 08 Oct 2025, 08:34Its a tough, demanding crowd here....
volvolugnutr
- 9 Replies
- 7678 Views
Last post by enriquepr21
- 930 Views
Last post by Uglyveedub
- 26 Replies
- 6385 Views
Last post by ChadLee
- 11 Replies
- 4840 Views
Last post by matthew1
- 1004 Views
Last post by azureblue
