It was working a week ago, now only warm air is blowing, where do I pour in the freon?
129,000
A/C doesn't work 1999 Volvo V70
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You don't "pour in the freon", it is a gas and comes in pressurised cans.
Read through the Official AC Thread for more info.
https://www.matthewsvolvosite.com/chat/p ... sc&start=0
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
JRL
- Year and Model: Several
- Been thanked: 16 times
This may work once but your Evaporator is probably shot or at best going south slowly.
EVERY SINGLE ONE OF THESE (Volvos) from 1994 -2000 need the evaps to be replaced at least once in their lifetime (they rot out)
Big job, $1500 bucks)
is this any good? or should I buy a regular can....
http://www.partsamerica.com/productdeta ... Code=3571B
JRL
The probablility is that your evaporator is shot.However, if yoiu must add R 134,ekoszyk wrote:is this any good? or should I buy a regular can....
These cars take EXACTLY 1.65 lbs, you add more and you mess up the system, you add less and it still won't cool properly.
If you believe that it's compleltely hot and empty, you need to be as close as possible to 1.65 lbs.
That being said, if it's completely empty you're probably wasting your time as it will leak out again and pretty quickly, (couple of days)!
If it went out that fast in a week you need to check the system. Is the compressor working, etc?
You also failed to post your miles, this IS important
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Yes, that should work, however, you need to check some other things first. Is the compressor clutch kicking on? Is the evaporator fan coming on?ekoszyk wrote:is this any good? or should I buy a regular can....
JRL wrote:The probablility is that your evaporator is shot.However, if yoiu must add R 134,ekoszyk wrote:is this any good? or should I buy a regular can....
http://www.partsamerica.com/productdeta ... Code=3571Bthe correct way is to evac the system and then out new freon in
Yes the fan is coming on....it's just I just bought this car used and it's a 1999 so I know it probably hasn't been filled in a while....
129,000
JRL
The clicking is the compressor coming on and off because of no freon.ekoszyk wrote:actually it makes a clicking sound under the hood when i turn the A/C on and the fan is working....
129,000
You don't "top it off", you shouldn't have do this on ANY CAR if it's in good condition.
As said, these cars usually require a new evaporator every 5 to 8 years. Have it filled PROPERLY and see how long it holds, it may hold (for a while) for months.
One of my cars needs an evaporator but one fill is good for a year so I have time.
Clean the entire (AC air intake) system out with a bleach and water solution to rid it of mildew, change the cabin filter ASAP, fill it with the EXACT amount of freon (1.65 lbs after removing any that's left in there) and see how your car reacts
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
I've owned my 1995 850 for 5 years now. It was in the family since new. When given to me 5 years ago it had to be refilled. Once a year in the summer I would refill it with a can of 134a, I would add enough to the top end of the green/yellow line on the gauge. This would prevent the compressor from clicking on and off.
Two years ago I replaced the receiver/dryer, it was rusted out. It was filled again and again, until finally a few weeks ago it finally won't hold a charge.
I guess what I'm saying is, fill it up, I wouldn't worry too much about getting an "exact 1.65 lbs" in the system personally. JRL is right, if you want to do it the correct way follow his advice! However shotgun filling it worked for 5 years in my case, however changing out the evap is next year's spring project. Can't wait!!
JRL how do you clean the system out with the bleach solution? I will need to do that next spring, my vents smell very bad.
1995 850 GLT Wagon w/ 200,000 miles
