I found a new way that water can leak into the back of the wagon, and fixed it. Took some photos along the way in case anybody else finds water dripping down the trim and wetting the carpet in the tailgate area.
After removing the interior side trim, water drop visible after splashing a little water on the rear roof of the car (red arrow shows droplet hanging from metal).
Once I understood where the water was coming in, I started searching for how the water was entering from the roof. I removed the little plastic end cap at the end of the trim and pried up the trim strip:
I found a black rubber strip next to the yellow clamp:
I removed the rubber strip, revealing the hole:
Over the years, the rubber delaminated a bit and failed to seal the hole completely, allowing water to get in.
I sealed the hole with a sealant, reinstalled outer trim strip.
We had a couple rainstorms since I sealed the hole, and I verified it's stayed dry.
Just thought I'd describe the leak-hunt and repair in case anybody else is having the same problem.
Need advice on best way to repair tailgate leak at hinge Topic is solved
Fix Leak at Tailgate Hinge and Roof Trim
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Re: Need advice on best way to repair tailgate leak at hinge
- Has thanked: 1836 times
- Been thanked: 1709 times
As you probably know, those are the mounting holes for the roof rail bolts. They are a tar type, I guess, 'self-healing' type material so that when the bolt passes through it, it seals against the threads to stop it leaking. I've seen it leak there on roof rails as they age also.
Thanks for the education and taking the time to write it down. Mush appreciated!
- Has thanked: 2652 times
- Been thanked: 1240 times
This is in the VRD. Thanks @jreed!
