- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Did you do a glove test before the soaking? If so let us know the after. Always wondered if degreasing could return the part back to service. Currently our 07 S60 2.5T is neutral in terms of the glove test. No suction nor inflating of the glove.
- rolsen11
- Year and Model: 2000 V70 SE
- Has thanked: 19 times
- Been thanked: 22 times
New Nissens heater core and recirc flap actuator arm on order from FCP, along with some interior clips and crush washers to get that free shipping. I'm excited to finally have some good heat, a couple days ago I had to drive to work in -20F temperatures, my fingers felt like popsicles the entire drive. Never again... I hope
2000 V70 SE - Bought sight unseen in Cleveland, currently my only car. Looks identical to my profile picture
Chieber
- Year and Model: 1998 v70
- Has thanked: 45 times
- Been thanked: 29 times
This is the original one on the car that I took off when I did the pcv job a couple months back.
I replaced it with an aftermarket one and kept the old apart.
But it seems there’s not much to the oil trap. This picture from cn90 shows the inside of it.
BTW. Anyone knows what this plastic bolt does? It’s on the accelerator pedal and doesn’t look like it’s connected to anything.
1/2 a shitbox V70 1998 2.5 NA
- Has thanked: 1498 times
- Been thanked: 3810 times
Got the s70 out and solved the no heat problem by adding coolant. 3 liters down.
- Has thanked: 1836 times
- Been thanked: 1709 times
Now that looks like a moose! Well done and the moose will thank you!!
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
That's a lot! Any idea where it's going?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Not yet. There is a seep at the right side radiator Metal-to-plastic tank junction. I hope that is it.
If not, both seats will have to come out to drain coolant out of the body pan...
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Found a couple of good parts out in the junkyard.
'99 -'00 turbo passenger side axle, and a V.V.T hub still on the cam.
I'll toss the cam.
I'll toss the cam.
1999 V70 GLT
1999 V70 GLT
